this is the latest version... though an rc .. I would recommend waiting till full final rlease is done b4 updating...
though you can download and run test using this version...
any modifications you have added will need to be redone for this version and recoded as the newer version user different code now... (though if you post your mods I am sure they will get updated for you or you can learn the new system)
There is a doc section in the download on how to update and the first post here...
I hope that helps..
