Comments |
Re: CustomIcy
I pinged MG, hopefully he'll be able to take a look in the upcoming days. Thanks for the report!
Informpro [ Sun 15 Jan, 2017 18:37 ]
Re: CustomIcy
Can you please try it now?
Mighty Gorgon [ Mon 16 Jan, 2017 22:12 ]
Re: CustomIcy
Thanks so much, Informpro y Luca You're awesome!!! God bless you both!!
Cristianita [ Fri 20 Jan, 2017 03:28 ]
Re: CustomIcy
Thank you very much.
Mighty Gorgon [ Tue 07 Feb, 2017 22:36 ]
Re: CustomIcy
Hi, all! God bless you!
I was trying to change some of the buttons, but I have noticed that something does not work very well. I cannot type the hexadecimal number of my color, instead I need to try to hit this moving the cursor, and it is impossible!
Is it normal? How can I choose exactly the right color?
Cristianita [ Sun 20 Aug, 2017 21:31 ]
Re: CustomIcy
I think it was done this way because it was supposed to be easier. Maybe it's not though...
Informpro [ Sun 20 Aug, 2017 23:41 ]
Re: CustomIcy
Not really easier... for example, my hexadecimal code is #acd5b7 could you image my cursor jumping and dancing trying to hit the correct number?
Cristianita [ Sun 20 Aug, 2017 23:49 ]
Re: CustomIcy
First off – which CustomIcy tool are you trying to use? Avatars, banners, templates, etc?
Informpro [ Mon 21 Aug, 2017 11:12 ]
Re: CustomIcy
I am trying to use buttons...
Cristianita [ Mon 21 Aug, 2017 23:26 ]
Re: CustomIcy
I will take a look.
Informpro [ Wed 23 Aug, 2017 00:59 ]
Re: CustomIcy
Thanks, Informpro
Cristianita [ Wed 23 Aug, 2017 08:10 ]
Re: CustomIcy
To the very right of the color picker, you can see #000000 etc
If those were editable would that be ok?
Informpro [ Wed 23 Aug, 2017 22:58 ]
Re: CustomIcy
Surely, Informpro!
Cristianita [ Fri 25 Aug, 2017 09:16 ]
Re: CustomIcy
Ok, I will try to take a look then.
MG: not too sure where the sources are?
Informpro [ Mon 28 Aug, 2017 09:52 ]
