Re: CustomIcy
I had a look at it and the whole feature should be recoded...
Since I don't think there is so much interest, at the moment this task will have a very low priority...
Anyway you can pass your color as a variable on the page, if you copy me the link of the page you want to customize, I will send a link with the right color set.
The time now is Fri 19 Apr, 2024 22:53 • All times are UTC + 1 Hour [DST enabled]
