Post phpBB XS Build 058 Changelog
Hi all.
In this topic you will find an almost complete Changelog for phpBB XS Build 058 (since Build 049):
  1. Added: Unread Post Information 2 Database (UPI2DB) MOD
    • Saves information about unread post in the database, so they remain unread even after logoff
    • Allowes marking posts unread again
    • Highlights unread and marked posts
    • Allowes to mark a post unread again after it was edited
    • Announcements and Global Announcements can't be marked read by clicking "Mark all Forums read", they have to be read
    • Can be activated or deactivated for the entire board - if deactivated, phpBB's Cookie system handles unread posts as it did before
    • Can be configured to allow activation on a per user basis, so every user can choose whether he/she wants to use it or not
  2. Added: Dropdown menu in header for New, Unread, Marked and Permanent Read posts
  3. Added: Country Flags
  4. Added: Topic viewcount isn't increased if the author views his own topic
  5. Added: ACP option to disable forum postcount on a per forum basis
  6. Added: ACP option to disable Lightbox JS if forum thumbnails are enabled
  7. Added: ACP option to disable Quick Quote JS for topics
  8. Added: ACP option to disable active content BBCode (allows to disable BBCode for Flash, Video, Stream, RealMedia, EMFF, YouTube and Quicktime)
  9. Added: Icons for own posts even in search and recent pages
  10. Added: Some new default profile fields (Phone, Other Info with BBCodes support)
  11. Added: Smileys in Quick Reply
  12. Added: Additional informations when viewing topic such as Lang and Style, switchable in ACP
  13. Added: Upgrading script rewritten... now support also updating from latest version of XS mode
  14. Added: Switch for disabling IP check upon registration
  15. Added: HTML links may now be shown only for registered users
  16. Added: Possibility to disable email sending error which may hangs some script
  17. Added: Added some Blocks for IM Portal and 2 Columns Layout now should work fine (also added one block position)
  18. Added: phpBB Visual Confirmation Code support
  19. Added: Smart Album Button in viewtopic with link to users personal gallery (if created)
  20. Added: ACP Sync Personal Pics Counter for old XS version without Pics Counter in users table
  21. Added: Now users may log on as hidden, visible or in default mode
  22. Added: Version checking may be disabled
  23. Added: Code may now be written using an alternative BBCode tag CODEBLOCK
  24. Added: Line Numbers in Code may now be disabled to speed up messages parsing (use linenumbers=false to exclude them)
  25. Added: New error management system
  26. Added: Switch for disabling some BBCodes in signatures and other sections
  27. Added: Added YouTube, Spoiler and EMFF BBCodes (even if still without buttons to quick insert them)
  28. Added: New file for applying some board settings quickly
  29. Added: Serbian Language
  30. Updated: BBCode Box
    • The BBCode Box got all new buttons
    • 2 additional buttons to align Album Images left and right
    • Extra Button for Ordered Lists
    • All buttons have a language coded alt and title tag now (except Quicktime)
    • Font type and font size shown in dropdown menu (not interpreted by IE6 or below)
    • Background color of dropdown menu changes properly with the template now
    • BBCode Help button in the upper right corner added
    • Postimage.org now opens in your language (for Italian, German, Spanish and Catalan)
  31. Updated: ACP completely reorganised for better administration
  32. Updated: CTracker to version 4.1.8
  33. Updated: FAP to latest available version plus some XS only features
  34. Fixed: Several template fixes and some changes in CSS
  35. Fixed: Download Post button now language coded
  36. Fixed: HTML special characters in Edit Notes now are shown correctly
  37. Fixed: Some BBCodes which weren't working correctly, and added TABLE support if HTML is enabled and table tag allowed in ACP
  38. Fixed: Shoutbox permissions
  39. Fixed: BBStats
  40. Fixed: Some statistics modules
  41. Fixed: Some inconsistent Nav Boxes in header
  42. Fixed: Removed a lot of blank spaces and reformatted a lot of XS files
  43. Fixed: URL in topic title are now not converted with autourl function
  44. Fixed: Created a new parsing function for BBCodes with some limitations for easy parsing
  45. Fixed: Local URLs in email notifications now are reported correctly
  46. Fixed: Guests in who viewed a topic weren't listed
  47. Fixed: RSS feed now has its own charset, so news should be parsed with the correct charset
  48. Fixed: Thumbnails in posts should now be generated correctly
  49. Fixed: Fixed some missed images in some templates and their definition in CFG file
  50. Fixed: Some vars were not escaped correctly before being passed to SQL
  51. Fixed: PAFileDB BBCodes are now BBCBMG compliant
  52. Fixed: Some date formats
  53. Fixed: Gender in memberlist
  54. Fixed: Signature were not parsed correctly
  55. Fixed: Some ACP options in Config section were not working properly
  56. Fixed: Some settings which may cause problems, are now disabled by default in a new XS setup
  57. Fixed: Admin Users which some vars not parsed correctly
  58. Fixed: Permission issue when setting Album Access to REG or upper levels
  59. Fixed: Acronyms, Autolinks, BBCode, HTML, Smileys not parsed correctly in news
  60. Fixed: Posting preview extra line breaks when HTML or BBCode OFF
  61. Fixed: Limit Image Width not working properly in posts
  62. Fixed: Fixed a couple of bugs in the installation files
  63. Fixed: Quick Quote feature was exposed to XSS injection
  64. Fixed: HTACCESS file now should now be executed faster
  65. Fixed: Errors in PM Archiving functions
If you want to keep your old 049 release clean... Here is a list of all the files that were in Build 049 and have been removed in Build 058:
  1. xs_root/error.php
  2. xs_root/remote_file_size.php
  3. xs_root/test_thumb.php
  4.
  5. xs_root/hl/phpbbsecurity.hl
  6.
  7. xs_root/images/bbcb_mg/images/*.*
  8.
  9. xs_root/language/lang_catala/flag_round.png
  10.
  11. xs_root/language/lang_spanish/flag.gif
  12. xs_root/language/lang_spanish/lang_phpbbmyadmin.php
  13. xs_root/language/lang_spanish/lang_rating.php
  14. xs_root/language/lang_spanish/lang_sai.php
  15. xs_root/language/lang_spanish/lang_usercp.php
  16.
  17. xs_root/templates/ca_aphrodite/bbcode.js
  18. xs_root/templates/ca_aphrodite/lightbox.css
  19. xs_root/templates/ca_aphrodite/lightbox.js
  20. xs_root/templates/ca_aphrodite/nav_quick_links_HIDE.tpl
  21. xs_root/templates/ca_aphrodite/scripts.js
  22. xs_root/templates/ca_aphrodite/sitemap.js
  23. xs_root/templates/ca_aphrodite/viewtopic_quickreply.tpl
  24.
  25. xs_root/templates/ca_aphrodite/images/black/icon_download.gif
  26. xs_root/templates/ca_aphrodite/images/black_yellow/icon_download.gif
  27. xs_root/templates/ca_aphrodite/images/blue/icon_download.gif
  28. xs_root/templates/ca_aphrodite/images/blue/lang_catala/icon_pa_download.gif.gif
  29. xs_root/templates/ca_aphrodite/images/blue/lang_spanish/icon_pa_download.gif.gif
  30. xs_root/templates/ca_aphrodite/images/cyan/icon_download.gif
  31. xs_root/templates/ca_aphrodite/images/dark_green/icon_download.gif
  32. xs_root/templates/ca_aphrodite/images/green/icon_download.gif
  33. xs_root/templates/ca_aphrodite/images/lite_blue/icon_download.gif
  34. xs_root/templates/ca_aphrodite/images/sblue/icon_download.gif
  35. xs_root/templates/ca_aphrodite/images/sgreen/icon_download.gif
  36. xs_root/templates/ca_aphrodite/images/sgreen/lang_catala/Thumbs.db
  37. xs_root/templates/ca_aphrodite/images/sgreen/lang_spanish/icon_online.gif.tmp
  38. xs_root/templates/ca_aphrodite/images/sgreen/lang_spanish/icon_online.gif_1.tmp
  39. xs_root/templates/ca_aphrodite/images/violet/icon_download.gif
If you are upgrading from a version which is prior to Build 058 I strongly recommend to remove error.php (do not confuse it with ERRORS.PHP which is a new file and it is needed), which could be exposed to a security issue.
Thanks for the useful Topic Mighty Gorgon:
zankyw (18 August)
Post Re: PhpBB XS Build 058 Changelog
Shouldn't be deleted too the file /images/icon_clip_old.png ?
www.LphantES.com
zankyw - View user's profileSend private messageVisit poster's website
Post Re: phpBB XS Build 058 Changelog
zankyw wrote: [View Post]
This file shouldn't be in XS 049... in any case, you can delete it if you wish.
Post
I've translated in italian the changelog...
Can be found here: http://www.phpbbplus.it/phpbbplus/release-058-vt3354.html
ganesh - View user's profileSend private messageVisit poster's website
ganesh wrote: [View Post]
Great work ganesh... thank you!
BTW... I translate "button" as "bottone"...
I'll change it ASAP...
Megabass
German changelog can be found here:
http://www.phpBBXS.de/viewtopic.php?t=107
No support via PM or E-Mail!
FAP 3, yeah baby, yeah!
Tom - View user's profileSend private messageVisit poster's websiteView user's personal gallery
Thx again MG!
www.LphantES.com
About the following line ...
I must delete all the files inside images/bbcb_mg/images/ and all subdirectories with its content ?
Lucky - View user's profileSend private message
Lucky wrote: [View Post]
Yes... delete and then upload only the files in the package for that folder.
Anyway, if you are not having problems with webspace I wouldn't worry about unused images... what is important is that you are removing unused PHP files.
thanks a lot!
ukiello - View user's profileSend private message
