Page 1 of 3
Limun
Location: ![[Censor] (Croatia) croatia.png](images/flags/croatia.png) [Censor]
 Work On NewTemplate For Icy 1.2
I'm working on new template for icy 1.2
its based on pearl blue....
see few shots
examples mouse off
mouse on
mouse write
this pics are gif so its not like in real
need your comments...
Edited by Guest, Mon 20 Oct, 2008 13:02: Spelling Optimised for the Search Engine. |
| 1 user likes this post • Share |
#1 Thu 06 Mar, 2008 17:55 |
Xusqui
 Re: Work On NewTemplate For Icy 1.2
WOW!!!! Awesome!!!
My users always want me to install dark styles, and they are not so frequent!!! I'm looking forward you to finish it to install it in my web!!!
Really amazing!!
Congratulations!!
____________ Icy Phoenix Latest 2.0 (working pending)
| Share |
#2 Thu 06 Mar, 2008 21:24 |
Limun
as i expected i have some problems in IE and only in IE
see...
opera/firefox
IE
any idea what this cause ??
Edited by Guest, Mon 20 Oct, 2008 13:03: Spelling Optimised for the Search Engine. |
| Share |
#3 Sat 08 Mar, 2008 15:59 |
Inactive User
With IE7,
You're going to have to get used to adding negative padding and margins to pull it shape.
Something like this:
padding:-3px;
margin-top:-3px;
It's difficult to say exactly what you need to do, but I had a lot of the same problems with this WIP, and so far have had to adjust or rewrite a lot of the templates. And still have some to go.
h**p://forum-styles.com/ip-themes/index.php
So try the padding/magin thing, if it don't work - post the header and the css you're using. (Preferably in a .zip file) and someone can take a look at it.
| Share |
#4 Mon 10 Mar, 2008 14:30 |
KasLimon
 Really great jobs both Limun's and Lopalong's!!
____________ Gabriel Anca
| Share |
#5 Mon 10 Mar, 2008 15:55 |
Inactive User
@ Limun
Do you have that theme 'live' on a test site ? If so, can you post the URL to it so that one can have a look with view-source, as it may help to speed up the problem of fixing it. (That's if you haven't already fixed it).
Thanks Kas,
I should have locked that site as it's ONLY for beta-testing new themes and group styles. That's why just about every template is "open". It might not look the best, but at least it shows where any problems are
This will be the Main Site. h**p://forum-styles.com/ip/forum.php
And today I'll do an update refresh on that theme.
| Share |
#6 Mon 10 Mar, 2008 23:19 |
Limun
hi here is one shoot of portal
i have question for you Lopalong..if is not secret,how did u made that mouse over buttons on your site...
and link is here
don't bother at domain the site is empty
<Link Removed>
Edited by Guest, Mon 20 Oct, 2008 13:01: Removed Link - Spelling Optimised for the Search Engine. |
| Share |
#7 Wed 12 Mar, 2008 05:23 |
Inactive User
Limun wrote: [View Post] i have qouestion for you Lopalong..if is not secret,how did u made that mause over buttons on your site...
It's "TOP SECRET"
Which images - Toplinks, or postbits?
And if you ask the question at my house, I'll post all of the code and requirements for it, so that everyone can use it.
Try this code for your problem. I also don't understand your path including p_blue Are you hard-coding this?
Change:
<td background="templates/mg_themes/images/p_blue/moj_style/top_header_c.png">
To:
<td class="top_header_c" width="100%">
Put in .css
td.top_header_c {
background-color: #000000;
background-image : url(images/p_blue/moj_style/top_header_c.png);
background-repeat : repeat-x;
border-collapse: collapse;
padding: 0 0 0 0;
margin: 0 0 0 0;
PLAY!
EDIT:
You also want to KILL all of the <td width=??, and image height=x width=x in the .cfg file applicable to p_blue. It only complicates things if there is other .css markup adding padding/margins to images etc.
| Share |
#8 Wed 12 Mar, 2008 06:15 |
Inactive User
Hi limun,
I've posted a response to your question here:
h**p://forum-styles.com/ip/in-answe...ere-vp6.html#p6
| Share |
#9 Thu 13 Mar, 2008 11:59 |
Nice job guys.
Let me know when you will finish your templates.
| Share |
#10 Sat 15 Mar, 2008 01:32 |
Limun
It's "TOP SECRET"
Change:
To:
Put in .css
td.top_header_c {
padding: 0 0 0 0;
margin: 0 0 0 0;
PLAY!
EDIT:
nothing happend...still same problem in IE
| Share |
#11 Fri 21 Mar, 2008 22:19 |
Limun
any help with this about IE ?
BTW...i want to export this style for release and give him hew name....
its edited blue pearl and i don't know how to do it...it just want do export,clone ecc...
Edited by Guest, Mon 20 Oct, 2008 13:05: Spelling Optimised for the Search Engine. |
| Share |
#12 Tue 25 Mar, 2008 10:15 |
Inactive User
Limun wrote: [View Post] any help with this about IE ?
BTW...i want to export this style for relase and give him hew name....
its edited blue pearl and i dont know how to do it...it just want do export,clone ecc...
G'day Limun,
Can you .zip up MG_Themes with your modifications and PM me a link to download it so that I can have a look at it, as it's far too difficult to assume what the other person has done in the way of modifying the .tpl files and the .css, and try to offer ways to fix it.
Cloning: If you have modified any other .tpl files apart from the header and footer, and the .css then you would possibly have to make it a new Group-Theme. If you have only modified those mentioned files, then it could be added to MG_Themes. Either way, the procedures are different to add it to IP.
If you want some help with this, let's sort out the IE problem first.
| Share |
#13 Tue 25 Mar, 2008 11:17 |
Limun
Lopalong check PM
| Share |
#14 Tue 25 Mar, 2008 12:25 |
Inactive User
Hi Limun,
This should fix it and it's been tested in both IE7 and FF, and all resolutions.
The logo is no longer part of the header layout, so you will have to create a new logo for it.
You could also rename "top_header_cl.png" to logo.png.
I've left the old logo in place and added some height and width (Which you should remove when you make a new logo for it). So as to give you some idea of what was changed.
The Code:
ADD BETWEEN: ##<!-- {GREETING_POPUP} -->##
<table width="100%" border="0" align="center" cellspacing="0" cellpadding="0">
<td><img border="0" src="{T_IMAGESET_PATH}top_header_l.png" alt="">
<td class="top_header_c" width="80%"><a href="{U_PORTAL}"><img src="{T_IMAGESET_PATH}top_header_cl.png" height="120px" width="300px" alt="{L_HOME}" title="{L_HOME}"/></a>
<td class="top_header_c"><!-- BEGIN switch_header_banner --><center>{HEADER_BANNER_CODE}</center><!-- END switch_header_banner --></td>
<td class="top_header_c" width="100%"></td>
<td align="right" vertical-align="top"><img border="0" src="{T_IMAGESET_PATH}top_header_r.png" alt="">
</td></td></td>
</table>
AND: ###<table id="forumtable" width="100%" cellspacing="0" cellpadding="0"> ##
The .CSS ## Just replace the old markup. You could also move this image to p_blue ?##
td.top_header_c {
border-collapse:collapse;
One other small thing - Every image should have an alt= even if it's only alt="", else it will never pass validation.
Cheers!
Lopalong.
| Share |
#15 Wed 26 Mar, 2008 05:27 |
Page 1 of 3
| Link this topic |
| URL |
| BBCode |
| HTML |
