Page 2 of 2
Goto page Previous  1, 2
Post Re: Phpbbxs Exceeding The Resources Account
RvG wrote: [View Post]
very soon very very soon as soon as phpbb3 released...
Mighty, are you going to use phpbb3 once it became final? coz It have ability to control the server load.
No, I will continue to use phpBB 2... I'll switch to phpBB 3 only when it will became stable.
invi wrote: [View Post]
MG and because nonexempt some mods in future versions? ,
I believe better that serious, is MODs that really is not used, and to have them of adornment and to see as they consuming SQL.
For example, the file of the site, the statistics, HTTP referers. it is not my opinion, and the serious XS something lighter. there is much people whom it will also like sudoku, but many do not use, and I believe it either that normal the serious thing that these “mods” came in pack to part, not including.
not if I explain myself, which they are possible to be installed of the easiest way the user than it wants them, would be less misfortunes with ours hosting.
I bad feel it by my English, I hope that you understand to me without problems.
Thank You.
invi, I'm focusing all my efforts to try to make mods perfectly integrated and deactivable.
Sudoku is totally independent... you can remove the link and the files related without affecting anything... it is totally indipendent.
Statistics mod is the same. No extra SQL added... it is stand alone.
Site history is adding extra SQL... but again is deactivable.
Referrer is involved only when the session is created... so only 1 SQL per session... I think it is totally trascurable...
If you want to limit your SQL charge, you have to play with the settings in ACP... I hope to find the time to remove some other extra SQL with an extra ACP switch... I'm still working on it.
I believe that Area 69 is quite fast... the server where this site is hosted is a shared server, and it is quite fast...
Ok MG, then good, there is no problem, thanks for your answer, Merry Christmas and new year
There are two types of people, those who know and those who do not.
inviSend private message
Ok MG, then good, there is no problem, thanks for your answer, Merry Christmas and new year;)
Merry Christmas to you and your family too...
Hi MG,
I have also the problem . 3 days ago hosting suspended me my account because of XS was exceeding the resources of the cpu of the shared account (Specially viewtopic.php). I had disable signs, and I had turned slow googlebot.
I have disable things I dont use. ¿Is there any solution?
Thanks!
My 2 IP Forums:
tiolalu wrote: [View Post]
Hi MG,
Thanks!
Use Icy Phoenix instead of XS... you can better control your traffic.
Thanks! I will do, but I prefer to wait to "final" version, because if anything fails people will kill me xD.
My 2 IP Forums:
What I can suggest is trying to switch off features which requires CPU charge like Limit Image Width, Thumbnails In Posts... you can also switch off something in ACP => DB...
I had all DB options in off...
How to turn off Limit Image Width and Thumbnails In Posts?
My 2 IP Forums:
Check ACP - General - Limit Image Width and ACP - Configuration - Posting - Images in Posting
Post new topic  Reply to topic  Page 2 of 2
