SOLVED I Can't Find The Correct Place To Insert The Codes To Verify The Ownership Of My Forum In Google Search Console
Subject: I Can't Find The Correct Place To Insert The Codes To Verify The Ownership Of My Forum In Google Search Console
I got a tracking ID, and a global tag:
<!-- Global site tag (gtag.js) - Google Analytics -->
<script async src="https://www.googletagmanager.com/gtag/js?id=UA-xxxxxx"></script>
<script>
window.dataLayer = window.dataLayer || [];
function gtag(){dataLayer.push(arguments);}
gtag('js', new Date());
gtag('config', 'UA-xxxxxxx');
</script>
But I'm not sure where I have to add this code, because the page says that I have to add it in the first element <HEAD> of each page I want to follow up on. I found out that ACP has a place like this, but am I right? Is SEO of the General Settings.
I have also this code:
google-site-verification: googlexxxxxxxxx.html
Subject: Re: I Can't Find The Correct Place To Insert The Codes To Verify The Ownership Of My Forum In Google Search Console
I couldn't find the place, but I could verify the ownership of my forum adding a CName in Hostinger.
Thanks anyway :mryellow:
Subject: Re: [SOLVED] I Can't Find The Correct Place To Insert The Codes To Verify The Ownership Of My Forum In Google Search Console
Congrats. I admit I had no idea about such things :).
Informpro wrote: [View Post]
Well, there is a place in the ACP where you can add some codes of Google Adsense and Google Analytics:
5238181658
Maybe avatar Mighty Gorgon knows about that...
But Google Analytics's place doesn't work. None of the codes I inserted work, as I said :oops: Maybe I didn't know how to add the code, maybe I added the wrong code..
Generation Time: 0.5657s (PHP: 4% SQL: 96%)
SQL queries: 32 - Debug Off - GZIP Enabled
