Post I'm Doing A Test To See Why My Website Appears Unsafe And I Get This (TEMA CERRADO)
Mixed Content - Errors
Hard Failure
A style-sheet with an insecure url of "http://islademenorca.org/templates/prosilver_ip/style_blue.css" was loaded on line: 47 of https://www.islademenorca.org/.
This URL will need to be updated to use a secure URL for your padlock to return.
Hard Failure
A script with an insecure url of "http://islademenorca.org/templates/common/js/ip_scripts.js" was loaded on line: 102 of https://www.islademenorca.org/.
Hard Failure
A script with an insecure url of "http://islademenorca.org/templates/common/js/prototype.js" was loaded on line: 103 of https://www.islademenorca.org/.
Hard Failure
A script with an insecure url of "http://islademenorca.org/templates/common/js/run_active_content.js" was loaded on line: 104 of https://www.islademenorca.org/.
Hard Failure
A script with an insecure url of "http://islademenorca.org/templates/common/scriptaculous/scriptaculous.js" was loaded on line: 105 of https://www.islademenorca.org/.
I'm doing a test to see why my website appears unsafe and I get this.
the version of my Icy Phoenix 1.3.0.53b
Hard Failure
A script with an insecure url of "http://islademenorca.org/templates/common/js/ajax/ajax_core.js" was loaded on line: 123 of https://www.islademenorca.org/.
Hard Failure
A style-sheet with an insecure url of "http://islademenorca.org/templates/common/highslide/highslide.css" was loaded on line: 126 of https://www.islademenorca.org/.
Hard Failure
A script with an insecure url of "http://islademenorca.org/templates/common/highslide/highslide-full.packed.js" was loaded on line: 127 of https://www.islademenorca.org/.
Hard Failure
A file with an insecure url of "http://islademenorca.org/templates/prosilver_ip/style_css.php?color=blue&lang=english&xmas=false" was loaded on line: 181 of https://www.islademenorca.org/.
menorcaSend private messageSend e-mail to userVisit poster's website
Post Re: I'm Doing A Test To See Why My Website Appears Unsafe And I Get This
Like I said, this is because your website is mixing http and https.
If you want to use https, then you need to configure Icy Phoenix to use your domain with https:// prefix.
k I will put the permanent address and the hosting told me to force https in .htaccess,
in ACP/ configuration/ icyproenix server I have islademenorca.org as Domain Name
#Make sure the whole site goes to www.mysite.com instead of mysite.com. This is good for the search engines
#Edit and uncomment the below lines for your own site.
#Make sure to replace icyphoenix.com with your site address.
#RewriteCond %{HTTP_HOST} ^islademenorca.org
#RewriteRule (.*) https://www.islademenorca.org/> #RewriteRule (.*) https://www.islademenorca.org/$1 [R=301,L]< [R=301,L]
#Permanent redirection (the first line is the old domain, the second one is the new domain)
#RewriteCond %{HTTP_HOST} ^islademenorca.org [NC]
#RewriteRule ^(.*)$ https://www.islademenorca.org/> #RewriteRule ^(.*)$ https://www.islademenorca.org/$1 [R=301,L]< [R=301,L]
I would like to know what files I have to modify to eliminate the browser warning, my image is not secure and I have to update the url to https.
The permanent and forced 301 redirect is already solved at this step, I just need to know what file or where I have to fix it.
This website is safe, I suppose that with the warning of the images they have corrected it
This text above is wrong and I did not pay attention to its Google translation, in reality it gave an image error and an unsafe page
Post Re: I'm Doing A Test To See Why My Website Appears Unsafe And I Get This (TEMA CERRADO)
In ACP you need to enable the Cookie secure option:
ip_cookie_secure_20240217
Did you do that?
In the end it didn't work.
the permanent 301 redirect was forced.
The website showed a problem warning about the images and in the end I couldn't change the URL because I had no idea where to change it. Added to this was another error and I stopped displaying all the photographs on the website.
Tired of everything, I canceled the contracted service and canceled it...
The error was that of not secure cookies, I will take it into account again,
