Post Lightbox Doesn't Work (RC2)
Hello Everybody..
I'm trying to get working Lightbox, but it doesn't work..
I activated it on the ACP, but i don't see the effect in my images.. I have cleared Cache, and it doesn't work..
Is there any solution??
I have seen it in this forum, but in my forum it doesn't work..
Danielc - View user's profileSend private messageVisit poster's website
Post Re: Lightbox Doesn't Work (RC2)
I think you mean this...
 highslide
And "Make sure you empty the precompiled posts after changing this setting!"
Highslide works, but lightbox doesn't... I cleared the precompiled posts, but is the same thing... I have also disabled Highslide option, but it just causes that an image open a link when clicking on it..
Looks as you are right... same to me http://icyphoenix.de/viewtopic.php?f=13&t=59
Can anyone else confirm this?
You were right, there was a bug... I should have fixed it.
HEHEHE
Thanks for pointing that out Danielc
