Danielc
 ¿Make A Lightbox Image Set?
Hello Everybody..
I have installed the latest Icy Phoenix version and now lightbox works well (thanks MG), but i want to make an images set, so i can click on the picture and it shows the next image...
Is it possible???
#1 Sat 18 Jul, 2009 17:59 |
novice programmer
 Re: ¿Make A Lightbox Image Set?
Have you tried the album slideshow?
____________ ~~ novice programmer ~~
#2 Sat 18 Jul, 2009 19:04 |
DWho
Hello Everybody..
Is it possible???
use highslide instead of lightbox it will pick up any images on the page and allow you to go to them by using the next arrow
#3 Sat 18 Jul, 2009 19:55 |
Danielc
I'm not using Album images...
I know with HighSlide i can do that, but i like more the Lighbox effect...
#4 Sat 18 Jul, 2009 21:15 |
DWho
are you going to use this in post in topics...?
I will have alook tomorrow for you to see if it is possible..
#5 Sun 19 Jul, 2009 00:29 |
Danielc
Yeah, i want to use this in my posts..
Thanks!!
#6 Sun 19 Jul, 2009 01:28 |
buldo
... so i can click on the picture and it shows the next image...
Is it possible???
If you move your mouse pointer on nearly upper right corner of the image shown then yuo can browse the next image (the same for the previous moving the mouse pointer nearly the upper left corner).
Hope this is that you are searching for.
____________ ~~~ Andrea ~~~
User #379756 on Linux Counter
#7 Sun 19 Jul, 2009 22:15 |
Danielc
But that doesn't work for me...
#8 Mon 20 Jul, 2009 05:25 |
DWho
Having a quick look at how lightbox works... if you anted to have a next feature you have to recode the some icy code.. basically you need to tell it to group the images so it understands that you want to go to the next image...
I personally do not know how this can be achieved as it would mean delving into the code and figuring out how you can tell it that images on a page are grouped...
unless there is a modification of lightbox to make this easier i cant see a work around..
#9 Mon 20 Jul, 2009 10:22 |
Danielc
MMM, i have an idea... If i make a BBcode to tell Icy Phoenix that it's a group, could it work?..
Greetings..
#10 Mon 20 Jul, 2009 17:38 |
Greetings..
I think so... try with this code... it should work. also with lightbox
[img alt="Lena Gercke" slide=lena]http://www.lena-g.de/img/galerien/fotoshootings/audi-2007/bild1.jpg[/img] [img alt="Lena Gercke" slide=lena]http://www.lena-g.de/img/galerien/fotoshootings/audi-2007/bild2.jpg[/img] [img alt="Lena Gercke" slide=lena]http://www.lena-g.de/img/galerien/fotoshootings/audi-2007/bild3.jpg[/img]
____________ TheSteffen
#11 Tue 21 Jul, 2009 15:30 |
buldo
[quote user="TheSteffen" post="41549"] [img alt="Lena Gercke" slide=lena]http://www.lena-g.de/img/galerien/fotoshootings/audi-2007/bild1.jpg[/img] [img alt="Lena Gercke" slide=lena]http://www.lena-g.de/img/galerien/fotoshootings/audi-2007/bild2.jpg[/img] [img alt="Lena Gercke" slide=lena]http://www.lena-g.de/img/galerien/fotoshootings/audi-2007/bild3.jpg[/img]
With this code Lightbox works perfectly and you have the opportunity tp browse images with "Prev" and "Next" as I said before.
Thanks TheSteffen!
WOW!! What a nice... CAR!!
#12 Tue 21 Jul, 2009 18:58 |
Danielc
Yeah, it works perfectly... So, i just have to put the alt and slide tags, haven't i?
#13 Wed 22 Jul, 2009 00:05 |
KugeLSichA
CAR??? i dont see a car... my eyes are on the other object in the pictures
#14 Wed 22 Jul, 2009 08:32 |
Just the slide.
#15 Thu 23 Jul, 2009 13:08 |
| Link this topic |
| URL |
| BBCode |
| HTML |
