Problems Generating Some Thumbnails
Goto page Previous  1, 2
Subject: Re: Problems Generating Some Thumbnails
It is designed to be in the signature.. But it is only if you want.. You just have to use img tag with the url provided..
Thanks again..
Who provides the URL?
You need to make sure to replace all spaces by %20 for example...
I use .htaccess to generate the url's... The url's are written by the user..
<?php
* Ranking Image Builder for Miiconsola.com
* Desarrollado por Danielc
* @version 1.0
* @copyright 2009
define('IMG_THUMB', true);
define('CT_SECLEVEL', 'MEDIUM');
$ct_ignoregvar = array('');
if (!defined('IP_ROOT_PATH')) define('IP_ROOT_PATH', '../');
if (!defined('PHP_EXT')) define('PHP_EXT', substr(strrchr(__FILE__, '.'), 1));
include(IP_ROOT_PATH . 'common.' . PHP_EXT);
$username = isset($_GET["usuario"]) ? $_GET["usuario"]: "Usuario no especificado";
$jpg = isset($_GET["jpg"]) ? $_GET["jpg"]: 0;
//message_die(GENERAL_ERROR,"Usuario = $username", '', __LINE__, __FILE__, $sql);
$username = str_replace('\"','',$username);
$font_size = 7;
$n_font_size = 11;
$avatar_size = 83;
$avatar_pos_x = 13;
$avatar_pos_y = 8.5;
$ruta_avatar = "";
$name_pos_x = 109;
$name_pos_y = 22.5;
$points_pos_x = 214;
$points_pos_y = 41.5;
$base_img = imagecreatefrompng(IP_ROOT_PATH . 'images/ranking_base.png');
$rank_image = imagecreatetruecolor(imagesx($base_img), imagesy($base_img));
$partidas = 0;
$ganadas = 0;
$perdidas = 0;
$puntos = 0;
$ranking = 0;
$star = imagecreatefrompng(IP_ROOT_PATH . 'images/ranking_star.png');
$fuente = IP_ROOT_PATH . 'fuentes/doom.ttf';
$req_thumb_size = 400;
$pic_thumbnail_prefix = '';
if ($username != "Usuario no especificado") {
$sql = 'SELECT user_avatar, user_allowavatar, ranking_perdidas, ranking_ganadas, ranking_puntos
FROM ' . USERS_TABLE . '
WHERE username = "' . $username . '"';
if (($result = $db->sql_query($sql))) {
if($user_info = $db->sql_fetchrow($result))
imagecopy($rank_image,$base_img,0,0,0,0,imagesx($base_img),imagesy($base_img));
if ($user_info['user_allowavatar'] != 0) {
if ($user_info['user_avatar'] != "") {
$ruta_avatar = IP_ROOT_PATH . "images/avatars/" . $user_info['user_avatar'];
} else {
$ruta_avatar = IP_ROOT_PATH . "images/ranking_noavatar.png";
} else {
$ganadas = $user_info['ranking_ganadas'];
$perdidas = $user_info['ranking_perdidas'];
$partidas = $ganadas + $perdidas;
$puntos = $user_info['ranking_puntos'];
$ranking = ($ganadas + $perdidas) == 0 ? 0 :$puntos / ($partidas);
$file_part = explode('.', strtolower($ruta_avatar));
$pic_filetype = $file_part[count($file_part) - 1];
switch ($pic_filetype){
case 'jpg':
case 'jpeg':
$avatar = imagecreatefromjpeg($ruta_avatar);
break;
case 'gif':
$avatar = imagecreatefromgif($ruta_avatar);
break;
case 'png':
$avatar = imagecreatefrompng($ruta_avatar);
break;
default:
$av_x = imagesx($avatar);
$av_y = imagesy($avatar);
if ($av_x > $avatar_size || $av_y > $avatar_size) {
if ($av_x > $av_y) {
imagecopyresampled($rank_image,$avatar,$avatar_pos_x,$avatar_pos_y,0 ,0,$avatar_size,$avatar_size * ($av_y / $av_x) ,$av_x, $av_y);
} elseif ($av_y > $av_x) {
imagecopyresampled($rank_image,$avatar,$avatar_pos_x,$avatar_pos_y,0 ,0,$avatar_size* ($av_x / $av_y),$avatar_size ,$av_x, $av_y);
} else {
imagecopyresampled($rank_image,$avatar,$avatar_pos_x,$avatar_pos_y,0 ,0,$avatar_size,$avatar_size ,$av_x, $av_y);
} else {
imagecopy($rank_image,$avatar,$avatar_pos_x,$avatar_pos_y,0,0,$av_x,$av_y);
$textcolor = ImageColorAllocate($rank_image,255,255,255);
imagettftext($rank_image,$n_font_size,0,$name_pos_x,$name_pos_y,$textcolor,$fuente,$username);
$name_pos_y += 19;
imagettftext($rank_image,$font_size,0,$name_pos_x,$name_pos_y,$textcolor,$fuente,"Partidas: $partidas");
$name_pos_y += 14;
imagettftext($rank_image,$font_size,0,$name_pos_x,$name_pos_y,$textcolor,$fuente,"Ganadas: $ganadas");
$name_pos_y += 14;
imagettftext($rank_image,$font_size,0,$name_pos_x,$name_pos_y,$textcolor,$fuente,"Perdidas: $perdidas");
imagettftext($rank_image,$font_size,0,$points_pos_x,$points_pos_y,$textcolor,$fuente,"Puntos: $puntos");
$points_pos_y += 4;
imagecopy($rank_image,$star,$points_pos_x,$points_pos_y,0 ,0,imagesx($star), imagesy($star) );
$points_pos_y += 18;
$points_pos_x += 6 + imagesx($star);
imagettftext($rank_image,11,0,$points_pos_x,$points_pos_y,$textcolor,$fuente,$ranking);
if ($jpg == 0) {
$pic_id = "www.rankings.miiconsola.com/$username.png";
$pic_thumbnail_prefix = 'mid_' . md5($pic_id);
$pic_thumbnail = $pic_thumbnail_prefix . '_' . $username . '.png';
$pic_thumbnail_fullpath = POSTED_IMAGES_THUMBS_PATH . $pic_thumbnail;
//if(!file_exists($pic_thumbnail_fullpath)) {
imagepng($rank_image, $pic_thumbnail_fullpath,9, PNG_ALL_FILTERS);
@chmod($pic_thumbnail_fullpath, 0777);
header('Content-type: image/png');
imagepng($rank_image, NULL,9, PNG_ALL_FILTERS);
} else {
//message_die(GENERAL_ERROR,"jpg = 1. Comprobando.. jpg = $jpg", '');
$pic_id = "www.rankings.miiconsola.com/$username.jpg";
$pic_thumbnail = $pic_thumbnail_prefix . '_' . $username . '.jpg';
imagejpeg($rank_image,$pic_thumbnail_fullpath, 75);
header('Content-type: image/jpeg');
imagejpeg($rank_image, NULL, 75);
imagedestroy($rank_image);
} else {
message_die(GENERAL_ERROR,"Usuario no encontrado.", '');
} else {
message_die(GENERAL_ERROR,"No se pudo obtener la información para el usuario", '');
} else {
message_die(GENERAL_ERROR,"Usuario no especificado", '');
That is the code...
So, i must do what you say in the .htaccess or in the php file?? I was thinking on double rewrite the url via htaccess, but i don't think that is the best method..
Could you help me?
Did you solve this or is the issue still open?
I solve it generating the thumbnails manually and rewriting the urls.
Thanks for your help!
Page 2 of 2
Design by DiDiDaDo
Generation Time: 0.1996s (PHP: 13% SQL: 87%)
SQL queries: 15 - Debug On - GZIP Enabled
