Post New Thanks Per Post MOD
Hey folks,
I have rewritten the normal Thanks per Topic post to Thanks per POST... and have opened a new Topic to keep questions about the 2 different MODs clean...
Some code is taken from spydie in this topic -> http://www.icyphoenix.com/viewtopic.php?f=2&t=7714
If you have installed spydie´s thanks per post MOD, first you need to completly deinstall the MOD!
In my MOD you can activate/deactivate the MOD via ACP (where the normal Thanks settings was)
    Whats the difference?
  • Thanks per Post in all Forums where Thank Post are allowed -> config via ACP Forum settings
  • you can turn on/off the complete Thanks MOD via ACP -> Icy Phoenix Settings -> SQL Opti
  • you can also set up if you want to show "Thanks given" / "Thanks received" in viewtopic and profile
  • you can search for the thanks and thanks_given Posts
  • uses lang files
  • works also with CASH MOD (if enabled)
If you want to install this MOD, do a complete backup of your files AND database...
Screenshots & Demo:
 thanks_1 thanks_2 thanks_3 thanks_4
 thanks_5
DEMO: viewtopic -> http://www.blademaniacs.de/viewtopic.php?f=1&t=516
DEMO: profile -> http://www.blademaniacs.de/profile.php?mode=viewprofile&u=2 (maybe not viewable as guest)
Please post errors and/or suggestions in this topic...
Special Thanks to spydie and TheSteffen
images.rar
Description: Thanks buttons for english, german, spanish...
Many Thanks to TheSteffen for creating these...
Filename: images.rar
Filesize: 2.04 KB
Downloaded: 322 Time(s)
Play Games at GamesCampus!
Edited by KugeLSichA, Thu 24 Mar, 2011 17:26: added screens and links
Post Re: New Thanks Per Post MOD
Could you give some example web? For that I have long installed the mod thanks and let me know that this brings improvements
Version de Icy Phoenix: 1.3.0.53b
Hosting: Dedicado RM Hosts
URL: www.phonesfera.com & www.ps3fan.es & www.mypesepe.es
My_PeSePeSend private messageVisit poster's website
yupp.. for sure... but i´m updating my web ATM... if i´m done i´ll post the link here
Depending on your features says, that comes to your profile where you thanked an. If it is true I'll have to update mine. If not, then I'll leave it as is
KugeLSichA, very good job and very useful.
although I think instead we call it Thanks, would be better to call it I Like.
But since it is not even sure that will be incorporated in the new version of Phoenix, we avoid many of us to installed it, on live site, to not have a problem in the next upgrade.
CostaSend private message
EDIT:
Screenshot and DEMO Links added to first post
Costa wrote: [View Post]
yupp... but you can be sure, if there is a new version available... i will update my mod to work with the new one...
Is the same except that this is set in the ACP. What I seek is that the profile shows where you were grateful. I'll give you an example of thanks to vbulletin
ejemplog
My_PeSePe wrote: [View Post]
ejemplog
you can do this via the search page... which is included in my MOD
if you want, you can register on my page... then go to the DEMO Topic i posted in th first post... and the klick on the number near "Thanks received" / "Thanks given"... this is only viewable... if you are not a guest...
then on the search page, you can see the results as topics, where the user thanked and/or got his thanks...
Where´s the difference ???
Identical.
same with lang german.
Maybe a select foult ??
spydie wrote: [View Post]
Identical.
changed TOPIC to POST
Ok, now then as I upgrade mine xD
KugeLSichA wrote: [View Post]
Identical.
Where are my glasses
If you have the Thanks MOD from spydie installed... maybe you can save your current thanks per post... requieres some MySQL Knowledge
Spanish translation
Spanish translation
Spydie entonces meto tu traduccion sola ?/ Spydie then I put your translation alone?
