[SOLVED]My Forum On Google
Article
Reply with quote    Download Post
Post Re: My Forum On Google
DarkGhost wrote: [View Post]
I have after my txt change delted my Cachses
Yes otherwise I would not have been able to see it, now I guess it's a matter of time, I think there are ways to request a new crawl but you would have to find how to do that yourself because I can't remember   .
____________________
Edit: maybe search on the keywords "google webmaster" to find a few links with info like this one http://www.google.com/webmasters/
Joshua203 - View user's profile Send private message
Joshua203 [ Tue 28 Jun, 2011 13:10 ]
Comments
thx guys its sloved
DarkGhost - View user's profile Send private message
DarkGhost [ Sun 03 Jul, 2011 00:41 ]
Post Re: [SOLVED]My Forum On Google
I guess it's better to move all these info in the DB... since spiders are not multilanguage and users are not reading meta.
Added to To Do List.
Mighty Gorgon - View user's profile Send private message
Mighty Gorgon [ Sun 10 Jul, 2011 21:01 ]
Thanks, had same issue. Solved after reading this topic.  Thanks again.
beaudecor - View user's profile Send private message
beaudecor [ Tue 06 Sep, 2011 15:15 ]
Feature implemented... META data can now be specified also in ACP.
Mighty Gorgon [ Wed 07 Sep, 2011 20:41 ]
Ghostsearcher wrote: [View Post]
Off Topic
(i've now made it hurt your eyes to draw attention)
Ahhhhrgh....help... i can't write anymore!
But just a BTW question: Isn't it possible to change the meta tags in the ACP?
Just asking because well, you know me, i'm curious.
Greetings, Ghostsearcher
Yes it is! Styles & Templates > Edit Templates > "Icy Phoenix" = (root folder)
Edit your ".htaccess" and other things through that too.
Hans - View user's profile Send private message
Hans [ Sat 17 Sep, 2011 11:15 ]
Google takes time to crawl your site again and find the new to be able to correct it ...I have checked your site some time ago and found the changed codes (keywords and description)
I think if you submit a sitemap Google will crawl the site faster.
nichart291 - View user's profile Send private message
nichart291 [ Tue 18 Oct, 2011 21:38 ]
No prob.
Well, but i think there should be a function for it in the ACP menue. I mean, that's easier and would be more comfortable to the look&feel of icy. Icy is so mighty and really high adaptable, that's why i'm saying i miss that, too.
Just my mind. ^^
Hmm, maybe anyone should give this hint to mighty gorgon. Can i? ... and where?
Check the latest version of IP: there is Go in ACP -> General Settings -> Server and you'll find:
SITE_META_KEYWORDS
SITE_META_KEYWORDS_SWITCH
SITE_META_KEYWORDS_SWITCH_EXPLAIN
SITE_META_DESCRIPTION
SITE_META_DESCRIPTION_SWITCH
SITE_META_DESCRIPTION_SWITCH_EXPLAIN
SITE_META_AUTHOR
SITE_META_AUTHOR_SWITCH
SITE_META_AUTHOR_SWITCH_EXPLAIN
SITE_META_COPYRIGHT
SITE_META_COPYRIGHT_SWITCH
SITE_META_COPYRIGHT_SWITCH_EXPLAIN
Well it should be with the right lang variables, I just put it this way to make it clear =D
Edit: ah, didn't noticed the second page ! MightyGorgon the mightiest
Yros - View user's profile Send private message
Yros [ Tue 18 Oct, 2011 22:31 ]
I don't think crawlbots still care about these meta tags ... I read somewhere that they were just listed as a word in the page.
Informpro - View user's profile Send private message
Informpro [ Wed 19 Oct, 2011 19:46 ]
Post new topic  Reply to topic  Page 2 of 2
Goto page Previous  1, 2
