Post The Newest Registered User Is Guest
I approved a user, then quickly realized it was a spambot.  Deleted the user and this is what is at the bottom of the main forum page:
The newest registered user is Guest
When you click on the "Guest" username/hyperlink it goes to:
Sorry, but that user does not exist.
Any input for this one?
BeachTyme - View user's profileSend private message
Post Re: The Newest Registered User Is Guest
Ask someone to create a new account or create one yourself ...I think that would be a quickfix
Joshua203 - View user's profileSend private messageVisit poster's websitePersonal Gallery
clear cache.
or go to your db
look for users_table and check for the last entry
I cleared the cache and ran most of the DB tools prior to posting this thread.
I did join myself as a test user and emptied the cache again, then deleted the test user and the same problem has come back.
I'll have some time to check in to this a little further this weekend.
This issue is very strange... which version of Icy Phoenix are you using?
Mighty Gorgon - View user's profileSend private messageVisit poster's websitePersonal Gallery
