| Comments |
 Re: Automatic Ranks
spydie [ Mon 25 Jun, 2012 17:30 ]
 Re: Automatic Ranks
Yep, I know, but that way doesn't allow to set "Automatic rank per written messages" as default. In other words, if I look into a new user profile, it has mark "Messages per days" as default in the second row. Thank you anyway for your attention
Sarakin [ Mon 25 Jun, 2012 18:17 ]
 Re: Automatic Ranks
maybe this can help you
http://www.icyphoenix.com/viewtopic...ghlight=#p30350
read careful answers affter my post
Limun [ Mon 25 Jun, 2012 18:40 ]
 Re: Automatic Ranks
Thank you very much, but I already knew that kind of solution. IMHO, it's only temporary, because when we got a new user the table VALUE will be the same "NULL", right? The point is to address the issue in order to be fixed in future releases through the Admin Panel, because if I have to do a change manually, I can do so user by user too.
Sarakin [ Mon 25 Jun, 2012 19:23 ]
 Re: Automatic Ranks
Maybe I just don't understand the question but could it be as simple as this?
And then after this, you add more ranks but then with higher numbers for minimum messages
Joshua203 [ Mon 25 Jun, 2012 20:57 ]
 Re: Automatic Ranks
this was, what i meant.
spydie [ Mon 25 Jun, 2012 21:55 ]
 Re: Automatic Ranks
Hmmm, maybe the issue is that new registered users don't take by default the automatic rank per post written because there's no such rank with 0 messages... forget that. I've just tried to do so with no success. Newcomers still got no rank assigned in row 1 (NULL value in the table) and per days in the second one. Anyway, if we had created other ranks previously working per X messages written, they should change automaticly, right? Then, they don't, that's the point. It's not a critical bug, but maybe it should be taken into account for the next Icy release.
EDIT: I also tried adding an image to the rank, with no success  Maybe if I were able to link a rank to a group the problem could be solved easier...
Sarakin [ Tue 26 Jun, 2012 01:28 ]
 Re: Automatic Ranks
Sorry Spydie but I thought mentioning setting it to zero posts could maybe clear this up.
Sarakin, can you tell us what version you use of Icy?
After testing some more I noticed that an older version needed "DB And Security >> Database Maintenance >> Check user and group tables" to use the new settings at board level (at ACP level it is immediately used!) ...after that it works!
The new version already seems to do what you suggest ... no DB maintenance needed
PS... This could also depend on some other settings instead of the version used ...I'm not sure
Joshua203 [ Tue 26 Jun, 2012 14:50 ]
 Re: Automatic Ranks
1.3.0.53b is the last official version, right? If you're talking about this version, I can't find the "DB and Security" in the ACP  Do you mean the Cracker Tracker tab? Could you post a screenshot, please?
Sarakin [ Tue 26 Jun, 2012 16:29 ]
 Re: Automatic Ranks
Well if I can find it in the Icy Phoenix 1.3.0.53a, surely you should have it in the "b" version
PS ..if a new user actually registers it seems to update it all too after that
Joshua203 [ Tue 26 Jun, 2012 16:58 ]
 Re: Automatic Ranks
I'm sorry to tell... but no, .53b hasn't that tab, neither that checking user table options (I wish it had, cause they are important tools there, but sadly it has not). It seems it all goes through CrackerTracker and Library options (and/or only God knows how many different places they have spread), but I haven't seen that particular option about checking groups. Nevertheless, maybe using the .53a URL of that option could work. Could you share it in order to give it a try?
Sarakin [ Tue 26 Jun, 2012 21:49 ]
 Re: Automatic Ranks
Sarakin, TheSteffen has tipped me that you are probably not a full admin when you are in the ACP, this would be a good reason for you not to see all functions there.
to check this you can open includes/constants.php
define('MAIN_ADMINS_ID', '2');
and change it to:
define('MAIN_ADMINS_ID', '2,XXX');
where XXX would be your current user number (don't forget the komma (,) to separate them)
Thanks TheSteffen for your input!!!
Joshua203 [ Tue 26 Jun, 2012 23:03 ]
 Re: Automatic Ranks
Ok, thanks! That solved the hidden tab issue, but ranks are still ignored in the first row. Any other idea? Are there any other way to set in the first rank row "Auto per posts written" as a global rule and to keep it that way for the future?
EDIT:
Okay, all of this is a little easier than I thought. There's no other way to do this than edit the structure of the users table through phpMyAdmin and change the value "NULL" by "0" in the "user_rank" field. This way every new user enters with the autorank set through posts. Then, in order to set all users with that same value in user_rank (row1) we can use any SQL sentence you posted (the sintaxis is easy to understand) and after that setting again the special ranks we could have created previosuly, one by one.
It's a tough solution, but if you have a reasonable number of special ranks, it's doable in 10 or 15 minutes. Anyway, thanks for the support, and for the main admin tip!
Sarakin [ Wed 27 Jun, 2012 00:08 ]
 Re: Automatic Ranks
I'm sorry I still think you should just create a rank for 0 posts users, or I'm completely lost in what you are trying to do
Joshua203 [ Thu 28 Jun, 2012 12:34 ]
