Informpro
 Fix For "Ajax Like" (plus Some Other Features, Certainly)
Hey,
here's my fix for the "like this post" AJaX feature (and certainly other features).
I can't use git tool ATM, so I can't fix this through a new branch. Anyway, here's the way to fix it.
OPEN - templates/default/viewtopic_inc_js.tpl
FIND - <!-- IF S_POSTS_LIKES -->
AFTER, ADD - <script type="text/javascript" src="{FULL_SITE_PATH}{T_COMMON_TPL_PATH}js/ajax/ajax_core.js"></script>
OPEN - templates/common/js/ajax/ajax_core.js
AFTER, ADD - var ajax_page_charset = 'utf-8';
Please tell me if this fix worked for you :). (ofc, you need to enable "thanks", both the global switch and for the forum itself).
#1 Mon 30 Jul, 2012 13:44 |
Thanks for the useful Topic Informpro: ThE KuKa (30 July) |
 Re: Fix For "Ajax Like" (plus Some Other Features, Certainly)
Thanks for reporting... I have fixed this differently.
#2 Mon 30 Jul, 2012 21:26 |
mort
This is going to get into a mess if you two don't communicate the bugs and fixes you decide on before posting them. Otherwise we're going to get into a hell of a mess with constantly adding or removing things because one is doing it different to the other.
So MG, what's your fix for it? Because that's the one that will be regarded as the "Official" fix.
____________ My advice is freely given on the assumption that you will ignore any part or all of it!
My Hobby
#3 Tue 31 Jul, 2012 03:26 |
The fact is that we communicate via Instant Messenger and use GIT as "social coding" instrument.
This means that all code amendments are transparent to the world.
Maybe you are not used to it... but I would suggest to have a try.
Here is the link to latest commit with the fix:
Icy Phoenix 2.0 First Bugs Fixed
There is no need to discuss here, because all development discussions take place there, which is the proper place to do that.
#4 Tue 31 Jul, 2012 09:30 |
Informpro
Hey mort,
I don't have "write" access to the IcyPhoenix repo. I'm just giving here the problems I've encountered so far, and how I've resolved it (I could do that in the repo's issues, but then nobody here would know how to fix it, since everything would be on github). Mighty Gorgon is the only one to decide how to fix it, There's too many things I don't know about the internals.
#5 Tue 31 Jul, 2012 10:43 |
mort
@MG
Sounds good - Leads to less confusion.
I understand how GIT works and have applied all the patches that are currently there and also book-marked the url.
I agree with the "Dev" discussions at GIT, but the "Natives" who are ONLY capable of using the front end of Icy Phoenix might disagree if the patches/fixes are not posted here ASAP - whether they be in the form of files or code strings.
@ Informpro
"There's too many things I don't know about the internals."
Hi Informpro,
Welcome to the Club!
I agree that bugs and fixes should be posted here as soon as possible, and in a way that the every-day-person understands how to go about applying them.
GITHUB is after all the programmers domain - and is not for the average user who needs step by step instructions.
And although I didn't see your fix posted on GITHUB - I'll apply it anyway.
Thanks!
My Hobby
#6 Tue 31 Jul, 2012 11:05 |
Informpro
It's because Mighty Gorgon fixed it differently. I don't post snippets there, I'd chose to open a pull request if I had my computer but I can't do that with my iPhone.
MG's fix is here : https://github.com/MightyGorgon/icy...86deaa234486149 (only the last edit, on viewtopic.php)
#7 Tue 31 Jul, 2012 11:38 |
mort
Thanks,
So I just removed "your" fix.
Confusing - Isn't it?
My Hobby
#8 Tue 31 Jul, 2012 12:10 |
Well, this is arguable anyway. I used to release patches and releases very often in the past, trying to keep the system the most update possible. Only later I realized that some patches while apparently fixing some issues, were causing other issues elsewhere. I have then decided to update the package only after proper testing was performed. Of course you cannot be 100% sure either, but at least you minimize the problems that some "production" sites may have.
In other words, I would release immediately only patches which could be critical, while I would prefer to wait some time to test things properly for minor bugs (which affects only a small number of sites/features).
I agree on posting code snippets here... but only after the bug and the fix has been confirmed. I think the same practice is implemented in almost all projects.
#9 Tue 31 Jul, 2012 16:40 |
mort
Can't argue with that!
My Hobby
#10 Wed 01 Aug, 2012 00:53 |
| Link this topic |
| URL |
| BBCode |
| HTML |
Similar Topics
Similar Topics
