Page 5 of 5
Goto page Previous  1, 2, 3, 4, 5
Post Re: SOLVED Integramod And Icy Phoenix Questions
Hey Informpro,
**EDIT**
Never mind. I will come back and let you know what I was going to say  . i got an issue suddenly I'm not sure how to fix. I'll try my best on my own first. All my forums are gone. I can go to view forum and all topics are there, but if I choose a topic, I get the old This post does not exist error. This happened suddenly. I can't recreate it because I am not sure what I did. All I been doing since I verified the forums worked was adding all my cms pages and parent blocks. literally that is all.
**EDIT**
Cash Plugin off of Git was installed. Icy version I used was the one off of Git as well. When I disable the cash plugin I get my forums back and in working order. If I reenable the cash plugin again I get this:
Fatal error: Call to a member function generate_columns() on a non-object in C:\wamp\www\littleelm\viewtopic.php on line 656
Call Stack
#    Time    Memory    Function    Location
1    0.0180    772640    {main}( )    ..\viewtopic.php:0
If I go back in to the plugin it self on the config page and disable the plugin, I get the same error. The only way to stop the error and get the forums back is to go in to the plugins panel and disable it all together.
So I have verified this is NOT related to the upgrade to icy from phpBB.
Just to be sure I gave the exact info correctly the plugin cash came from Git. The version of Icy I am using is 2.2.2.107
**EDIT**
"Don't gain the world and lose your soul, wisdom is better than silver and gold" -Bob Marley
MWE_001Send private message
Okay, noted. I'll try to look during the week, maybe wednesday.
Sounds good.
Post Re: Integramod And Icy Phoenix Questions
Actually -- would you mind opening a new topic? I think this one has lived long enough already (...and is already marked as solved).
My thoughts exactly man. Going to bed now. It's late. I'll open one for you in the morning. =}
Post new topic  Reply to topic  Page 5 of 5
