Post Help, Problems With New Installation!
Regards! I have this problem when trying to install my test forum on my pc.
What could you do about it?
An error occurred trying to update the database
BLOB, TEXT, GEOMETRY or JSON column 'forum_rules' can't have a default value
Thank you for providing some solution.
ronalitoSend private message
Post Re: Help, Problems With New Installation!
Hi, which version are you try to install?
OPEN install/schemas/mysql_schema.sql
FIND SOMETHING LIKE THIS
    `forum_rules` ********,
    `forum_rules` TEXT NOT NULL,
Hi avatar Mighty Gorgon, is the  ip_20160604_220105
I'll see what I can do with what you tell me.
Is the last version that is on this page.
Nothing that I can install, it will not have to update something so that it adapts to the new of php & msql????
Have you tried a new installation currently on a local server?
mysql has two DB engines: InnoDB and Myisam.
Depending on the one you use, some features might produce an issue, and I think that's what's happening here.
Hi avatar Informpro Have you tried a new installation? If so, can you help me? I could not install icy????
Can you please tell me your version of PHP, Apache and MySQL just to be sure?
WAMPSERVER
Version 3.0.6 - 32bit
Server Configuration
Apache Version:
    2.4.23
PHP Version:
    5.6.25
Server Software:
    Apache/2.4.23 (Win32) PHP/5.6.25 - Port defined for Apache: 80
I can try as well. I have a WAMP installed and ready to go.
Can you tell us exactly what error/s you are getting? It will not only help to help you right now, but help us fix this for future use as well.
Screenshots work real nice as well. Photobucket is no longer an option without paying them 0 per year. So if you do choose screenshots, try uploading to your album herre or using a offline site like imgur or something like that.
Take care!
**EDIT**
Ok I got the exact same WAMP server installed per the OP thread.
Here is what I gather so far:
1.We need to release a patch real bad! Ok a patch would not work either. Maybe a minor upgrade and new release? If a patch was pushed it ouwld be just as easy to upgrade 2 files in the install folder and release a new minor updated version. We still have a storage engine issue that was reported long ago.
2. Once engine was fixed, the forum  rules error as told to us and luca commented on did in fact appear right on schedule.
3. Applying the fix Luca stated we now get this:
Field 'forum_rules' doesn't have a default value
So what if after we run the fix Luca suggested, we then alter the table via a query to this: ALTER TABLE phpbb_forums ALTER forum_rules SET DEFAULT ''  ??
**EDIT**
Just tried my fix to the fix and got this:
This is a strict mode BUG with MySQL and windows servers. I am going to try a live install on my linux server at a Data Center and see if the error exists.
Since the Op is trying to install on a WAMP server, I seriously doubt he is going to hack his own server. So in theory, any WAMp user can shut off strict mode and all should be well.
And also, I did a test install on linux and it installed flawless. No errors at all. not even the storage issue came up ironically enough. So i guess a patch or new version is not needed. So far all the errors seem windows related. I stand corrected if I am wrong.
Here is my Linux info if it helps any:
Apache Version     2.2.31
PHP Version     5.6.30
MySQL Version     5.5.51-38.2
Architecture     x86_64
Operating System     linux
Ronalito - Give me some time today and let me work on this and I will figure out how to do a install on WAMP Server without errors. It might take me a while as my code skills are slipping a bit in my older age
**EDIT**
Ok Ronalito problem solved.
in your system tray, click on WAMP icon and mouse over MySQL and choose my.ini
look for
;sql-mode=""
replace with
sql-mode=""
Save this file and Restart all services to WAMP.
if you get the Storage engine error, in your icy phoenix install/schemas folder
Open mysql_schema.sql and find at the top of the file
SET storage_engine=MYISAM;
Change it to
SET default_storage_engine=MYISAM;
Open sql_update_ip.php
Find
$sql[] = "SET storage_engine=MYISAM";
Replace with
$sql[] = "SET default_storage_engine=MYISAM";
Save and close all files.
Those modifications right there will allow you to install Icy Phoenix on you WAMP server error free. Now please understand, I am not responsible for any damage that may result if you use my fixes. This worked for me but might not for you. Use at your own risk!
**DISCLAIMER**
This edit will shut off strict mode in you MySQL!!!!! Please be aware of that. Do not use this WAMP as a live server. if you do, please understand what we just did to make your install work.
Enjoy your new install!!!
if you have any other questions please feel free to come back and post and will help as soon as possible.
"Don't gain the world and lose your soul, wisdom is better than silver and gold" -Bob Marley
MWE_001Send private message
Wow, that's a great write-up. Thank you!
Not a problem at all. If it helps someone running a Windows server or a WAMP then I have enjoyed helping as usual as so many others have helped me.
We need to release an update... I'll try to find the time for doing it.
Really, thank you very much for the help! I followed everything to the letter and as if by magic it worked, I thought my problem would not be solved and like an angel in the sky avatar MWE_001 appeared, totally grateful I am, I am short with so much patience and help provided. Thank you!
I did not answer before because I did not have internet, and yes, avatar Mighty Gorgon this project needs an update and count on my help to be a beta tester.
Thank you and God bless you, Long live to icyphoenix
Hello Ronalito.
I am glad my fixes worked out for you. It was my pleasure to med a helping hand. In the process of helping you, it also helped me as well as I was having issues with my WAMP stack as well.
Take care and if there is anything else we can do, please give us a shout! That is why we are all here is a community.
Good thing I found this thread
CatrionaLozano52Send private messageVisit poster's website
HideSimilar Topics
Topic Author Forum Replies Last Post
This topic is locked: you cannot edit posts or make replies. Installation Problem. dk-wamp Old Support Topics 4 Thu 26 Apr, 2007 02:08 View latest post
No new posts Installation Error wizzard Old Support Topics 2 Sat 05 Jan, 2008 05:59 View latest post
wizzard
No new posts Installation Error strangeone Old Support Topics 2 Tue 02 Dec, 2008 02:16 View latest post
Limun
No new posts Icy Installation k3v1n Old Support Topics 1 Fri 08 May, 2009 13:55 View latest post
DWho
No new posts New Installation Of Icyphoenix menorca General Support 2 Tue 06 Oct, 2020 13:03 View latest post
menorca
