Post May I Have Some Tutorial To Install Plugins?
Hi, God bless you!
I'm trying to install donation and sudoku plugins in my forum; but it's very confuse to me.
  • If I upload to FTP the whole package (i.e. ip_plugin_sudoku_20160604_100) with all files including, the ACP doesn't recognize the plugin; just not appears.
  • If I choose only files from ip_root (as the instructions says), it's the same problem: doesn't appear.
  • If I upload from next and next file, sometimes plugin appears in the ACP, but it doesn't install, it's impossible.
I have no idea how can I install the plugins. Any suggestion?
I upload plugins to plugin folder of FTP.
CristianitaSend private messageVisit poster's website
Post Re: May I Have Some Tutorial To Install Plugins?
You want to upload ip_root's contents to your root folder.
That means if the sudoku plugins has
ip_root/sudoku.php
You want sudoku.php in your forum root.
That's why there's a
ip_root/plugins/sudoku
Filezilla will add the directory to the /plugins/ path
I tried to install sudoku and chat using two different ways, but none works.
I uploaded two plugins in two differents ways: one from IP Root folder and the other from the plugin itself:
 plugins_1
But appears just one in ACP, the Sudoku Plugin.
 plugins_2
But even the sudoku plugin is in the ACP, it's impossible to install it, because I click "install":
 plugins_3
But the plugin still uninstall:
 plugins_4
So what it's the correct way to install a plugin?
Which IP version do you have? The one from here or from GIT?
The GIT version has a bug, but I fixed it on my side, MG should get the fixes soon:
https://github.com/MightyGorgon/icy_phoenix/pull/140
From this page http://www.icyphoenix.com/dload.php?action=category&cat_id=18
No, I do not mean the plugin.
I mean Icy Phoenix itself. Where did you download it?
Informpro wrote: [View Post]
I downloaded Icy Phoenix from this forum http://www.icyphoenix.com/dload.php?action=file&file_id=187
Okay. We will publish a new version soon I think this should fix your issues.
Oh, it will be great, Informpro!
I'll be waiting for that
