Comments |
 Re: Images Don't Show When Was Not Uploaded Through Forum
What do you mean "from the internet"? Did they use the img bbcode?
Informpro [ Tue 17 Apr, 2018 11:17 ]
Yes, she did it... I mean, URL directly from the other site. The image was not upload to the forum.
Cristianita [ Tue 17 Apr, 2018 17:15 ]
So, if they are not uploaded, they do not count towards your server's storage space. Unless you have enabled thumbnails, in which case Icy Phoenix will generate smaller versions of your images to display inline.
If they have used the img tag, it should work normally. Do you have an example page where it doesn't work?
Informpro [ Thu 19 Apr, 2018 18:05 ]
And if a website has hotlink protection, it will not work either. I agree on the thumbnails part.
If you can provide a link to the image your user is trying to use from the internet, I will try to replicate the problem on one of my own websites as well.
**UPDATE**
I have tried to post images from the internet form 2 different image hosting websites and both worked. Here is 1 example. This image is hosted at imgur.com :
http://prntscr.com/jbw6le <------------- CLICK ME
MWE_001 [ Mon 30 Apr, 2018 11:46 ]
I think the user took the URL directly from other website, not an image hosting... Either way I had to change the images, I uploaded them in my server storage.
I will ask her to post other images in the same way, and then I'll come back to give you the example.
Cristianita [ Tue 01 May, 2018 02:06 ]
Ok. Sounds good.
Websites have a thing called hotlink protection. That is where I can not take anything from your site without your permission. By doing this, people are stealing bandwidth off of other websites. It is frowned upon. I use hotlink protection on my sites (well, when I had websites).
if the website that the images were linked from has hotlink enabled, the images will never appear for you. And I have even coded websites when hotlink protected to show a picture of a guy shooting someone the middle finger and call them a thief.
But please do let us know how the person got the image and link, where they got it and how they posted it. That will help us narrow it down some for you hopefully.
Take care and have a blessed day.
Ray
MWE_001 [ Wed 02 May, 2018 00:07 ]
Thank you very much, Ray... I'm waiting for her answer
Cristianita [ Wed 02 May, 2018 01:39 ]
Ok, here is the URL:
[img]https://i62.servimg.com/u/f62/15/32/42/92/codex_48.jpg[/img]
The image is not showing in my forum:
https://elcaminocorrecto.com.mx/la-novicia-rebelde-la-historia-veridica-de-la-familia-von-trapp-vp224.html#p224
Cristianita [ Thu 03 May, 2018 04:13 ]
Hmm That is kind of odd it is showing no thumbnail, yet if I click, it opens up lightbox and shows the image. Let me check some things out. I'll get back to you today hopefully.
MWE_001 [ Fri 04 May, 2018 13:50 ]
Maybe you have some settings on your server which prevents the image to be shown.
It doesn't work with any image?
Mighty Gorgon [ Fri 04 May, 2018 22:32 ]
Thank you, MWE_001
Maybe, MG, but do you know where can I find this setting? Because I was looking for it but I've got nothing.
Cristianita [ Sat 05 May, 2018 20:28 ]
