Post [BETA]FAP 1.4.1 - SQL Generator V0.2
Hallo,
I've programmed a SQL generator for FAP 1.4.1 in Java. I hope you can understand it
Function:
First start the SQL-Gerator then go in options and modificate the fields for your album.
Then save and close the option Frame. After that you have to chose the path and then press create SQL.
In the dictory, where the pics are, is the generated SQL as an .txt file.
I hope you can understand my bad english
Bye Sorren
New version: v0.2
History:
01.03.08: Bug with " ' " in generated SQL fixed
27.02.08: SQL Preview added, Options in the main window, Bug .JPG solved, complete translation in english
FAP-SQLGenerator.zip
Filename: FAP-SQLGenerator.zip
Filesize: 8.37 KB
Downloaded: 53 Time(s)
Sorren - View user's profileSend private messageVisit poster's website
Thanks for the useful Topic Sorren:
KugeLSichA (26 February), JHOSMAN (27 February)
Post Re: [BETA]FAP 1.4.1 - SQL Generator V0.1
Wow, this could be very useful for users like me which usually upload pics manually.
I will have a try next time I need to upload pics in my album.
Thank you for sharing!
Thanks for sharing Sorren,
I will have a look at it.
That would be great And if you find some bugs, please post it here
Good work, it seems to work fine, but I, at the moment, prefer the "old" Excel sheet provided by MG.
Some tips/ideas:
- Why don't you include options fields directly in main winodow?
- I think that could be be useful if you may also provide an SQL preview.
Bugs:
- Files that have capital letters extension will not be included in SQL_generated.txt (eg. "image.PNG")
Minor thing:
- Some messages (when you restart the program) are in German.
Ciao,
~~~ Andrea ~~~
User #379756 on Linux Counter
buldo - View user's profileSend private messageVisit poster's website
OK thanks for your ideas
If corrected the Problem with the diffrent endings of the pics.
Now the program see .jpg, .JPG, .png, .PNG, .gif, .GIF .
Now in the DOS-Box are all comments on english
I think, i change the Option window in the main window. But not now later.
And a preview? Do you mean a textfield and in it is the hole SQL Code?
Bye Sorren
Sorren wrote: [View Post]
Yes, bur not hole SQL, just the first query.
~~~ Andrea ~~~
OK, thats an intresting idea ... i see what i can do
ok i've solved your ideas i hope you can give me more of them
Post Re: [BETA]FAP 1.4.1 - SQL Generator V0.2
Good work, but at the moment I prefer the "old" Excel sheet provided by MG because I want to insert more than one pic at once.
Anyway, thanks for sharing it.
^^ you haven't understand the program, the program can generate a sql syntax of a hole dictonary! ... Not only one picture, mark one picture in your dictonary klick on create SQL an then see into the marked dictonary. In it is the file SQL_generated.txt which contains for every picture a SQL statement.
