Post FAP SUPPORT - Abum Pack 1.4.1 Error
hi folks ....i installed the nice album pack 1.4.1 and everything look like very focntionnal accpet when  i go to my admin panel ...i click on configuration for the album but i got this error:
Forbidden
You don't have permission to access /forum/admin/admin_album_config_extended.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Can someone can tell me what is that error?? please
i added an attachement to see how its look like
thanks alot
404 error.zip
Description: screenshot
Filename: 404 error.zip
Filesize: 157.96 KB
Downloaded: 104 Time(s)
centrmtlSend private message
Post Re: Abum Pack 1.4.1 Error
Topic moved to "FAP Support"
You are using phpbb2 or phpbb3?
Because this FAP is till now only for phpBB2
phpbb2 im using
no one can help me ????
and also users cant delete there pics i try to find to let them delet theyre pics
i m speaking on blind because i dont use that so i cant check it     but to me seems that you didnt setup permisions ...
did you made this
CHMOD 777 album_mod/upload
CHMOD 777 album_mod/upload/cache
CHMOD 777 album_mod/upload/med_cache
CHMOD 777 album_mod/upload/otf
CHMOD 777 album_mod/upload/wm_cache
also check if you have admin_album_config_extended.php in your /forum/admin/ .... and if is seted to CHMOD 644
Limun wrote: [View Post]
did you made this
thnaks alot for the reply...
Yes all you just tell me its done ....but the admin files it was not on 644 but i try ...same problem...
  just because of that all my user cant delete there pics
did you saw this about deleting ?
http://www.icyphoenix.com/viewtopic.php?f=24&t=3994
and about first problem , i have no idea for now
No for that im ok i see these link about edit and delete ...its more about your "not authauriazed" page after i try or my member try to delete them.
The problem come from the configuration in ACP panel the one i cant acceed ....The rest like "Categorie,Permission and Personal gallerie link works..i can acceed to them ...but when i press configuration ..i got that message like on the first post(on the top) Seen like it got a glitch some where...But i found a post somewhere somme one have the same problem ..he change some code but for all php album mod ..this sound like ridiculous to do all these files ..if someone or even me can find where is the error...Look this topics its look like of this one:::http://www.icyphoenix.com/viewtopic.php?f=24&t=967
Still need help for that problem,.. i need to get in this link to find a solution for an Warning i receive...Warning: strstr() [function.strstr]: Empty delimiter
So for now i think im gona remove that mod......
Which version of PHP are you using?
Can you provide a link to check the error?
SPAM - REMOVED
cocosanSend private message
