Zuker
 GoogleWords
This mod creates pages on your forum with 500 links to postings at your board.
The page has pagination in case your board has more then 500 searchwords.
The links are generated from the search_word tables
Search engines like google or msn or whatever can index the page and thus taking in all those links into there database.
Instruccions for Install:
- Edit files
OPEN
includes/page_tail.php
$template->assign_vars(array(
BEFORE, ADD
'L_GOOGLEPAGE' => $lang['googlepage'],
'L_GOOGLELINKTEXT' => $lang['googlelinktext'],
'U_GOOGLEPAGE' => 'googlewords.'.$phpEx,
OPEN
language/lang_english/lang_main.php
BEFORE, ADD
$lang['googlepage'] = 'Googlepage';
$lang['googlelinktext'] = 'GoogleWords';
$lang['Total_googlewordlinks'] = 'Total of GoogleWords links';
$lang['googlepage_alt'] = 'Go to the message where the words is at, if you cannot find the word there, it is probably part of a smiliecode.';
OPEN
templates/mg_themes/overall_footer.tpl
BEFORE, ADD
<a href="{U_GOOGLEPAGE}" alt="{L_GOOGLEPAGE}" title="{L_GOOGLEPAGE}">{L_GOOGLELINKTEXT}</a> -
- Upload the package
| Description: |
GoogleWords |
 Download |
| Filename: |
googlewords.rar |
| Filesize: |
2.15 KB |
| Downloaded: |
113 Time(s) |
#1 Mon 28 May, 2007 19:52 |
tc1967uk
 Re: GoogleWords
Sorry to be really dim, Zucker, but in simple terms what does this do?
#2 Mon 28 May, 2007 20:15 |
Zuker
 Re: GoogleWords
it's something like wordgraph
#3 Mon 28 May, 2007 20:20 |
tc1967uk
 Re: GoogleWords
But if we've already got WordGraph, why would we need another one? What's the benefit?
#4 Mon 28 May, 2007 20:24 |
Zuker
 Re: GoogleWords
Read the description.
#5 Mon 28 May, 2007 21:00 |
jz
 Re: GoogleWords
Fantastic stuff zuker
there are three lines like this one in page_tail.php
where exactly do we put the code?
#6 Mon 28 May, 2007 21:15 |
tc1967uk
 Re: GoogleWords
So it's an extra way of getting Google to index pages on your site?
#7 Mon 28 May, 2007 21:33 |
jz
 Re: GoogleWords
take a look at this,,, http://www.kaltersiashqiptare.com/googlewords.php
is it meant to give that kind of result ?
#8 Mon 28 May, 2007 22:07 |
jz
 Re: GoogleWords
as you can see, I don't get this results.
can you tell me if it has something to do with this:
BEFORE, ADD
#10 Tue 29 May, 2007 00:19 |
Zuker
 Re: GoogleWords
BEFORE, ADD
Nope, because lang vars are showing fine on your site.
I'll install it again and check if i miss something here
#11 Tue 29 May, 2007 12:40 |
jz
 Re: GoogleWords
thanks mate
#12 Tue 29 May, 2007 12:43 |
jz
 Re: GoogleWords
No zuker..
Still the same http://www.kaltersiashqiptare.com/googlewords.php
Can you have a look at my page_tail.php file
<?php
* page_tail.php
* begin : Saturday, Feb 13, 2001
* copyright : (C) 2001 The phpBB Group
* email : support@phpbb.com
* $Id: page_tail.php,v 1.27.2.3 2004/12/22 02:04:00 psotfx Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
if ( !defined('IN_PHPBB') )
die('Hacking attempt');
global $do_gzip_compress;
// Show the overall footer.
if( empty($gen_simple_header) && (!defined('HAS_DIED')) && (!defined('IN_LOGIN')) && ($importal_wide == true) && ($board_config['board_disable'] == false) )
$template->set_filenames(array('portal_tailcenter' => 'portal_page_tailcenter.tpl'));
if (portal_parse_blocks($portal_config['default_portal'], true, 'tailcenter'))
$template->assign_var('PORTAL_TAILCENTER', portal_assign_var_from_handle($template, 'portal_tailcenter'));
$template->set_filenames(array('portal_tailright' => 'portal_page_tailright.tpl'));
if (portal_parse_blocks($portal_config['default_portal'], true, 'tailright'))
$template->assign_var('FOOTER_WIDTH', $portal_config['footer_width']);
$template->assign_var('PORTAL_TAILRIGHT', portal_assign_var_from_handle($template, 'portal_tailright'));
$template->set_filenames(array('portal_tail' => 'portal_page_tail.tpl'));
portal_parse_blocks($portal_config['default_portal'], true, 'tail');
$template->assign_var('PORTAL_TAIL', portal_assign_var_from_handle($template, 'portal_tail'));
$template->set_filenames(array('overall_footer' => ( empty($gen_simple_header) ) ? 'overall_footer' . $head_foot_ext . '.tpl' : 'simple_footer.tpl'));
if ( $board_config['switch_footer_table'] == true )
$template->assign_block_vars('switch_footer_table', array(
'FOOTER_TEXT' => $board_config['footer_table_text'],
'L_STAFF_MESSAGE' => $lang['staff_message'],
if ( $board_config['switch_bottom_html_block'] == true )
$bottom_html_block_text = $board_config['bottom_html_block_text'];
else
$bottom_html_block_text = '';
include_once($phpbb_root_path . 'includes/functions_jr_admin.' . $phpEx);
$admin_link = jr_admin_make_admin_link();
// CrackerTracker v5.x
include_once($phpbb_root_path . 'ctracker/engines/ct_footer.' . $phpEx);
$output_login_status = ($userdata['ct_enable_ip_warn'])? $lang['ctracker_ma_on'] : $lang['ctracker_ma_off'];
//Begin Lo-Fi Mod
$lofi = '<a href="' . append_sid($path_parts . '?' . htmlspecialchars($_SERVER['QUERY_STRING']) .'&lofi=' . (empty($_COOKIE['lofi']) ? '1' : '0')) . '">' . (empty($_COOKIE['lofi']) ? ($lang['Lofi']) : ($lang['Full_Version']) ) . '</a><br />';
'L_LOFI' => $lang['Lofi'],
'L_FULL_VERSION' => $lang['Full_Version'],
'LOFI' => $lofi
//End Lo-Fi Mod
'TRANSLATION_INFO' => ( (isset($lang['TRANSLATION_INFO'])) && ($lang['TRANSLATION_INFO'] != '') ) ? ('<br /> ' . $lang['TRANSLATION_INFO']) : ( ((isset($lang['TRANSLATION'])) && ($lang['TRANSLATION'] != '') ) ? ('<br /> ' . $lang['TRANSLATION']) : ''),
'CRACKER_TRACKER_FOOTER' => create_footer_layout($ctracker_config->settings['footer_layout']),
'L_STATUS_LOGIN' => ($ctracker_config->settings['login_ip_check'])? sprintf($lang['ctracker_ipwarn_info'], $output_login_status) : '',
'CMS_ACP' => ( $cms_acp_url == '' ) ? '' : $cms_acp_url,
'ADMIN_LINK' => $admin_link
if ( $board_config['page_gen'] == 1 )
// Page generation time for Admin - BEGIN
/* Un-comment the line below to restrict Admins only to view page generation info */
//if($userdata['user_level'] == ADMIN)
$gzip_text = ($board_config['gzip_compress']) ? 'GZIP ' . $lang['Enabled']: 'GZIP ' . $lang['Disabled'];
$debug_text = (DEBUG == true) ? $lang['Debug_On'] : $lang['Debug_Off'];
$excuted_queries = $db->num_queries;
$mtime = microtime();
$mtime = explode(" ", $mtime);
$mtime = $mtime[1] + $mtime[0];
$endtime = $mtime;
$gentime = round(($endtime - $starttime), 4); // You can adjust the number 6
$sql_time = round($db->sql_time, 4);
$sql_part = round($sql_time / $gentime * 100);
$php_part = 100 - $sql_part;
if (function_exists('memory_get_usage'))
if ($memory_usage = memory_get_usage())
global $base_memory_usage;
$memory_usage -= $base_memory_usage;
$memory_usage = ($memory_usage >= 1048576) ? round((round($memory_usage / 1048576 * 100) / 100), 2) . ' ' . 'MB' : (($memory_usage >= 1024) ? round((round($memory_usage / 1024 * 100) / 100), 2) . ' ' . 'KB' : $memory_usage . ' ' . 'BYTES');
$gzip_text .= ' | Memory Usage: ' . $memory_usage;
'SPACER' => $images['spacer'],
'PAGE_GEN_TIME' => $lang['Page_Generation_Time'],
'GENERATION_TIME' => $gentime,
'NUMBER_QUERIES' => $excuted_queries,
'GZIP_TEXT' => $gzip_text,
'SQL_QUERIES' => $lang['SQL_Queries'],
'SQL_PART' => $sql_part,
'PHP_PART' => $php_part,
'OVERALL_QUERIES_TODAY' => $show_in_footer_today,
'OVERALL_QUERIES_TOP' => $show_in_footer_top,
'OVERALL_PAGES_VIEWED' => $spvt,
'DEBUG_TEXT' => $debug_text,
'BOTTOM_HTML_BLOCK' => $bottom_html_block_text,
$template->assign_block_vars('generation_time_switch', array() );
// Page generation time for Admin - END
$template->pparse('overall_footer');
// Close our DB connection.
$db->sql_close();
// Compress buffered output if required and send to browser
// URL Rewrite - BEGIN
if ( ($board_config['url_rw'] == true) || ( ($board_config['url_rw_guests'] == true) && ($userdata['user_id'] == ANONYMOUS) ) )
$contents = rewrite_urls(ob_get_contents());
else
$contents = ob_get_contents();
if( function_exists(ob_gzhandler) && ($board_config['gzip_compress'] == true) )
ob_end_clean();
ob_start('ob_gzhandler');
echo $contents;
ob_end_flush();
else
ob_end_clean();
echo $contents;
// URL Rewrite - END
exit;
#14 Tue 29 May, 2007 13:13 |
Zuker
 Re: GoogleWords
What version are u using? Because my page_tail.php it's diff from yours
- <?php
- * page_tail.php
- * begin : Saturday, Feb 13, 2001
- * copyright : (C) 2001 The phpBB Group
- * email : support@phpbb.com
- * $Id: page_tail.php,v 1.27.2.3 2004/12/22 02:04:00 psotfx Exp $
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; either version 2 of the License, or
- * (at your option) any later version.
- if ( !defined('IN_PHPBB') )
- die('Hacking attempt');
- global $do_gzip_compress;
- // Show the overall footer.
- if( empty($gen_simple_header) && (!defined('HAS_DIED')) && (!defined('IN_LOGIN')) && ($importal_wide == true) && ($board_config['board_disable'] == false) )
- $template->set_filenames(array('portal_tailcenter' => 'portal_page_tailcenter.tpl'));
- if (portal_parse_blocks($portal_config['default_portal'], true, 'tailcenter'))
- $template->assign_var('PORTAL_TAILCENTER', portal_assign_var_from_handle($template, 'portal_tailcenter'));
- $template->set_filenames(array('portal_tailright' => 'portal_page_tailright.tpl'));
- if (portal_parse_blocks($portal_config['default_portal'], true, 'tailright'))
- $template->assign_var('FOOTER_WIDTH', $portal_config['footer_width']);
- $template->assign_var('PORTAL_TAILRIGHT', portal_assign_var_from_handle($template, 'portal_tailright'));
- $template->set_filenames(array('portal_tail' => 'portal_page_tail.tpl'));
- portal_parse_blocks($portal_config['default_portal'], true, 'tail');
- $template->assign_var('PORTAL_TAIL', portal_assign_var_from_handle($template, 'portal_tail'));
- $template->set_filenames(array('overall_footer' => ( empty($gen_simple_header) ) ? 'overall_footer' . $head_foot_ext . '.tpl' : 'simple_footer.tpl'));
- if ( $board_config['switch_footer_table'] == true )
- $template->assign_block_vars('switch_footer_table', array(
- 'FOOTER_TEXT' => $board_config['footer_table_text'],
- 'L_STAFF_MESSAGE' => $lang['staff_message'],
- if ( $board_config['switch_bottom_html_block'] == true )
- $bottom_html_block_text = $board_config['bottom_html_block_text'];
- else
- $bottom_html_block_text = '';
- include_once($phpbb_root_path . 'includes/functions_jr_admin.' . $phpEx);
- $admin_link = jr_admin_make_admin_link();
- // CrackerTracker v5.x
- include_once($phpbb_root_path . 'ctracker/engines/ct_footer.' . $phpEx);
- $output_login_status = ($userdata['ct_enable_ip_warn'])? $lang['ctracker_ma_on'] : $lang['ctracker_ma_off'];
- //Begin Lo-Fi Mod
- $lofi = '<a href="' . append_sid($path_parts . '?' . htmlspecialchars($_SERVER['QUERY_STRING']) .'&lofi=' . (empty($_COOKIE['lofi']) ? '1' : '0')) . '">' . (empty($_COOKIE['lofi']) ? ($lang['Lofi']) : ($lang['Full_Version']) ) . '</a><br />';
- $template->assign_vars(array(
- 'L_GOOGLEPAGE' => $lang['googlepage'],
- 'L_GOOGLELINKTEXT' => $lang['googlelinktext'],
- 'U_GOOGLEPAGE' => 'googlewords.'.$phpEx,
- 'L_LOFI' => $lang['Lofi'],
- 'L_FULL_VERSION' => $lang['Full_Version'],
- 'LOFI' => $lofi
- //End Lo-Fi Mod
- 'TRANSLATION_INFO' => ( (isset($lang['TRANSLATION_INFO'])) && ($lang['TRANSLATION_INFO'] != '') ) ? ('<br /> ' . $lang['TRANSLATION_INFO']) : ( ((isset($lang['TRANSLATION'])) && ($lang['TRANSLATION'] != '') ) ? ('<br /> ' . $lang['TRANSLATION']) : ''),
- 'CRACKER_TRACKER_FOOTER' => create_footer_layout($ctracker_config->settings['footer_layout']),
- 'L_STATUS_LOGIN' => ($ctracker_config->settings['login_ip_check'])? sprintf($lang['ctracker_ipwarn_info'], $output_login_status) : '',
- 'CMS_ACP' => ( $cms_acp_url == '' ) ? '' : $cms_acp_url,
- 'ADMIN_LINK' => $admin_link
- if ( $board_config['page_gen'] == 1 )
- // Page generation time for Admin - BEGIN
- /* Un-comment the line below to restrict Admins only to view page generation info */
- //if($userdata['user_level'] == ADMIN)
- $gzip_text = ($board_config['gzip_compress']) ? 'GZIP ' . $lang['Enabled']: 'GZIP ' . $lang['Disabled'];
- $debug_text = (DEBUG == true) ? $lang['Debug_On'] : $lang['Debug_Off'];
- $excuted_queries = $db->num_queries;
- $mtime = microtime();
- $mtime = explode(" ", $mtime);
- $mtime = $mtime[1] + $mtime[0];
- $endtime = $mtime;
- $gentime = round(($endtime - $starttime), 4); // You can adjust the number 6
- $sql_time = round($db->sql_time, 4);
- $sql_part = round($sql_time / $gentime * 100);
- $php_part = 100 - $sql_part;
- if (function_exists('memory_get_usage'))
- if ($memory_usage = memory_get_usage())
- global $base_memory_usage;
- $memory_usage -= $base_memory_usage;
- $memory_usage = ($memory_usage >= 1048576) ? round((round($memory_usage / 1048576 * 100) / 100), 2) . ' ' . 'MB' : (($memory_usage >= 1024) ? round((round($memory_usage / 1024 * 100) / 100), 2) . ' ' . 'KB' : $memory_usage . ' ' . 'BYTES');
- $gzip_text .= ' | Memory Usage: ' . $memory_usage;
- 'SPACER' => $images['spacer'],
- 'PAGE_GEN_TIME' => $lang['Page_Generation_Time'],
- 'GENERATION_TIME' => $gentime,
- 'NUMBER_QUERIES' => $excuted_queries,
- 'GZIP_TEXT' => $gzip_text,
- 'SQL_QUERIES' => $lang['SQL_Queries'],
- 'SQL_PART' => $sql_part,
- 'PHP_PART' => $php_part,
- 'OVERALL_QUERIES_TODAY' => $show_in_footer_today,
- 'OVERALL_QUERIES_TOP' => $show_in_footer_top,
- 'OVERALL_PAGES_VIEWED' => $spvt,
- 'DEBUG_TEXT' => $debug_text,
- 'BOTTOM_HTML_BLOCK' => $bottom_html_block_text,
- $template->assign_block_vars('generation_time_switch', array() );
- // Page generation time for Admin - END
- $template->pparse('overall_footer');
- // Close our DB connection.
- $db->sql_close();
- // Compress buffered output if required and send to browser
- // URL Rewrite - BEGIN
- if ( ($board_config['url_rw'] == true) || ( ($board_config['url_rw_guests'] == true) && ($userdata['user_id'] == ANONYMOUS) ) )
- $contents = rewrite_urls(ob_get_contents());
- else
- $contents = ob_get_contents();
- if( function_exists(ob_gzhandler) && ($board_config['gzip_compress'] == true) )
- ob_end_clean();
- ob_start('ob_gzhandler');
- echo $contents;
- ob_end_flush();
- else
- ob_end_clean();
- echo $contents;
- // URL Rewrite - END
- exit;
#15 Tue 29 May, 2007 13:21 |
| Link this topic |
| URL |
| BBCode |
| HTML |
