Page 1 of 3
Goto page 1, 2, 3  Next
Post IP Country Flags
IP Country Flags 1.0.0 BETA-3
What is this mod for?
This mod adds the ability of taking user's country from IP. You can easily manage countries from ACP and add/delete IP ranges.
You can show user's flag everywhere near to their username, or only in viewtopic. You can also set which flag you want to show (user's profile or user's IP) in case of having the two of them available. You can set configuration from ACP -> Configuration -> Site -> Abilities.
Also, you can arrange memberlist by their IP country.
Demo board: iesmg.es/ip
Who created it?
This mod was created by Marco (3Di at phpbb.com). This mod was released here.
I've adapted it to Icy Phoenix, but this mod I show you has not all the features the original mod does. I think the current ones are enough.
Installation instructions
  1. Make a full backup of your forum, including database and files
    This is strictly necessary because this mod can damage your database.
  2. Download the attached package
  3. Delete or rename images/flags folder
  4. Upload all files and folders located in root/ directory to the root of your forum
  5. Login as administrator and run install_ip_cf.php (http://www.youripforum.com/install_ip_cf.php) and follow the instructions. Please use a browser that supports javascript and wait until the installer ends.
  6. Delete install_ip_cf.php file and ipcf_data folder
  7. Open file ip_country_flag_1.0.0B2.txt included in the package and follow the instructions
  8. Clean cache
  9. Enjoy your new implementation!
Update from BETA-2 to BETA-3
Update from BETA-1 to BETA-2
Suggestions and opinions are always welcome. Have a nice day!
ip_country_flag_1.0.0B3.zip
Filename: ip_country_flag_1.0.0B3.zip
Filesize: 1.42 MB
Downloaded: 528 Time(s)
Gabriel Anca
Edited by KasLimon, Sat 08 Mar, 2008 16:59: Updating Attachment
Edited by KasLimon, Sun 09 Mar, 2008 09:27: Uploading new package
Edited by KasLimon, Wed 16 Apr, 2008 23:25: Updated to BETA-3
KasLimon - View user's profileSend private messageVisit poster's website
Thanks for the useful Topic KasLimon:
ThE KuKa (08 March), JANU1535 (09 March), Mighty Gorgon (15 March), BEN-HUR (19 March), crimsonsun (02 June)
Post Re: IP Country Flags
Thanks Kas...i will test it tonight
Caramba
Limun - View user's profileSend private messageView user's personal gallery
Thanks Kas, MODification man!
ThE KuKa - www.IcyPhoenix.Es - www.phpBB-Es.COM - www.phpBBMODs.Es
ThE KuKa - Admin Icy Phoenix and Translation Group Leader.
ThE KuKa - View user's profileSend private messageVisit poster's website
KasLimon wrote: [View Post]
[*]Open file ip_country_flag_1.0.0B1.txt included in the package and follow the instructions
??    where is it ?
did u mean ipcf296a.txt
I'm sorry, I mixed files
In the old package it was original mod file (much bigger and longer). I've updated the package with the correct file.
Thank you for reporting and sorry for the mistake
Gabriel Anca
dontknow  First try -falied-   stop
ok see pics...
 1_1205038690_196272
and as not installed (because of erorr in first pic) i saw also this ..
 3
I've tested it a lot of times before releasing...
I'll correct them.
Greetings!
Gabriel Anca
Please download the package and upload new files to your forum (adm/admin_ip_cf_user_flags.php and install_ip_cf.php)
Then try again. Thank you for reporting.
Greetings!
Gabriel Anca
sec try
shoud i clean this table ip_cf_ip_to_iso3661_1 or delete ?
Well, now you can't go back. It's because of the first error, so enter to the install like this:
http://www.your_ip_board.com/install_ip_cf.php?step=2
Greetings!
Gabriel Anca
 5
now i go to that manual part
but see this...PS I didnt done yet manual part "ip_country_flag_1.0.0B1.txt"
 5s
You have to apply code changes related to constants.php.
Look at the txt
Greetings!
Gabriel Anca
Package updated to 1.0.0 BETA-2
Updating instructions are included in first post. Greets!
Gabriel Anca
Great job and support.
Thank you Kas.
The mod has been updated to 1.0.0 BETA-3 version.
What's new?
Updated all the IP database to make most of the IPs recognisable.
I'll do a full checking of all the features and I'll add new ones when the time let me...
Greets!
Gabriel Anca
