Page 3 of 5
Sarakin
Re: Medal System 0.4.6 For Icy Phoenix 1.2.0.27a
Now it works perfectly, I only have to change some lines in order to restore the Random Banner on pageheader.php and that's all! Thank you very very much, have I said it yet?
#31 Thu 25 Sep, 2008 13:54 |
Inactive User
#32 Thu 25 Sep, 2008 14:23 |
MaxTortora
I have installed the medal system but when I go to www.mysite.com/medals.php the page is white.
If I have not created any medals, the page shows that there are not medals but when I create a medal, the page medals.php become white and empty.
Why?
#33 Tue 07 Oct, 2008 17:26 |
Chaotic
#34 Tue 07 Oct, 2008 20:24 |
Inactive User
MaxTortora wrote: [View Post] I have installed the medal system but when I go to ***.mysite.com/medals.php the page is white.
Why?
Because you haven't followed the installation instructions correctly and have "broken" into some other script. Just like some other people have done.
Replace the files with the ones you did back up, and try again.
#35 Tue 07 Oct, 2008 23:52 |
fucile
Re: Medal System 0.4.6 For Icy Phoenix 1.2.0.27c
Why was not created a language file?
On the basis of future updates would be better to create a language file because otherwise you should beat to implement the mod every time and not only for routine but also for language
Can I change it in Italian?
#36 Wed 08 Oct, 2008 05:25 |
Inactive User
fucile wrote: [View Post] Why was not created a language file?
Because this is an English support forum - in case you haven't noticed.
It has a language file - In English - and also a complimentary Spanish $lang file!
Quote: Can I change it in Italian?
Please do, and then post the whole MOD on the icyphoenix.it site.
#37 Wed 08 Oct, 2008 05:43 |
fucile
I am in support Italian Moderator
I would work together to make the mod more stable
#38 Wed 08 Oct, 2008 05:59 |
Inactive User
Then as a moderator you set a bad example by using the quote button and not the reply button to answer the post immediately above the last one.
I've also re-written this MOD with some extra script for the next version of Icy Phoenix. It will come in English only, because some of the $lang strings have been changed.
#39 Wed 08 Oct, 2008 08:10 |
fucile
Unfortunately, no moderator in icy phoenix.com and then I behave like a simple user.
Thank you for everything
P.S. :
Sorry for my bad english
#40 Wed 08 Oct, 2008 19:34 |
Inactive User
fucile wrote: [View Post] Unfortunately, no moderator in icy phoenix.com and then I behave like a simple user.
What you are actually saying is that: "When you leave home, you also leave your manners behind"?
I must remember that.
#41 Thu 09 Oct, 2008 07:46 |
There is no need to flame.
Both of you are not acting as "moderators" here.
Being moderators or admins it is not just a matter of colors or ranks...
fucile I think you misunderstood what Lopalong is trying to say... you are asserting that this mod is not based upon a language file, while he is saying that it is language file based.
Please check again the package... and stay on topic.
#42 Thu 09 Oct, 2008 11:30 |
xmenfile
Recently, i had a problem with my site turns blank and i managed to fix that. Anyway, i had this mod work before and run fine. I have checked all my changes and uploaded all files, but some how i can't save medal display in viewtopic. When went to medal setting in ACE and checked yes display in viewtopic, then hit submit. there is no error message, but i go back to settings it switch back to "No" display in viewtopic.
Can I get some helps, please?
Thank you so much,
#43 Sat 18 Oct, 2008 17:55 |
Do the medals show fine in Profile?
I don't know this mod... but maybe you may try to reapply changes from scratch.
#44 Thu 30 Oct, 2008 12:20 |
xmenfile
yes Sir, medal is showing perfectly in profile.
#45 Thu 30 Oct, 2008 21:47 |
Page 3 of 5
