Post How To Send PM To All Users?
Just that, how to send PM to all users.
I think is a good idea to have a feature in the ACP to do that (just a suggestion ).
Thanks in advance.
tiolalu - View user's profileSend private messageVisit poster's website
Thanks for the useful Topic tiolalu:
TheSteffen (28 November), Mighty Gorgon (01 December), novice programmer (04 December)
Post Re: How To Send PM To All Users?
little modifications to work with ip but not tested! try it!
masspm.zip
Filename: masspm.zip
Filesize: 4.8 KB
Downloaded: 125 Time(s)
New Player - View user's profileSend private message
That will be awesome if it works.
If it is proven to work, we'll move it to the customizations forum.
Chaotic - View user's profileSend private messageVisit poster's websiteView user's personal gallery
thank you very much New Player
its working
BTW only little thing to do
do not search
// That's all Folks!
search
//$lang[''] = '';
and than add before lang vars from install.txt
 masspm
Limun - View user's profileSend private messageView user's personal gallery
Thanks for testing it out Limun!
Moving to Icy Phoenix Customizations!
Thank you!
SkyOne1982 - View user's profileSend private message
You know, this has to be one of the most useful MODs!  Thanks tiolalu for bringing this up, New Player for posting the MOD, and Limun for making that code change!
New Player, thanks for the code.
Chaotic, thanks for moving the thread
Limun, thanks for testing it!
Even if it works, the template is not perfect, and the php files is not respecting some Icy Phoenix coding standards.
This doesn't mean that the mod is unsecure... this just means that should be improved.
New Player, do you think you can improve it? I can give you some hints if you wish...
P.S.: a final note... this script will almost surely hang for boards with thousands of users.
Mighty Gorgon, is better to do it with a SQL query?
How to do it?
T.I.A.
tiolalu wrote: [View Post]
How to do it?
T.I.A.
No, you can use this mod, I think it is working fine, but only with small boards... if you have thousands users the system may timeout (unless you are able to set very high timeout value for your server) and all the notification emails may not be sent as well.
yes when you give me hints i try it
Try to duplicate the MASS EMAIL feature just by adding the code to send a PM before sending the email...
That code is already optimized for delayed and subdivided sending.
Start the job and then I'll help out.
Italian version ^^
** removed **
http://img407.imageshack.us/img407/...nnerbakabk0.png
HaoAsakura - View user's profileSend private messageVisit poster's website
@ HaoAsakura
Would you like to explain to me what the "Italian Version" is when it appears all you have changed is this:
$module['1610_Users']['Massen PM versenden'] = $filename;
To this: $module['1610_Users']['Invio PM di gruppo'] = $filename;
What you have suggested as the "Italian Version" is as buggy as hell - contains no improvements to make the code compatible or secure with Icy Phoenix (as suggested by MG) and is worthless, dangerous and whatever.
Edited by Lopalong, Mon 05 Jan, 2009 21:06: Off Topic removed
