Post BBCode in Download dload.php
did somebody know how can I activate BBCode for dowloads dload.php
That would be nice. Because you can insert IMG MP3 [b] and so oon.
Thanks a lot
Post Re: BBCode In Download Dload.php
Hi
I have this working for you in the long description part... you can show any bbcode that Icy has...
though you will have to type it in manually as there are no buttons...
The only problem I have come across and maybe someone else can help with is... when editing a file the bbcode turns into html I could not find how to stop this from happening... though the html does not work it will come back with all the tags showing.... you have to put the bbcode back in the box
Sorry I just could not figure another way...
anyway 2 files attached just backup the originals and copy these 2 over...
this is for beta release only
Let me know if there are anyother problems
bbcode in description.rar
Description: bbcode in long description for pafiledb
Filename: bbcode in description.rar
Filesize: 19.51 KB
Downloaded: 133 Time(s)
Edited by DWho, Wed 18 Mar, 2009 09:59: updated attachment with all correct files needed
Post Re: BBCode in Download dload.php
WOW thanks DWho for you work.
I will try it and let you know.
EDIT: If you already have some bbcode in description it only shows [ b ]text[ /b ] (the code)
And I got this if I edit one file via ACP
Fatal error: Call to a member function parse() on a non-object in /www/htdocs/includes/pafiledb/functions_pafiledb.php on line 1800
Thanks for any help.
oops
I forgot to save the updated file...
try the one attached
functions_pafiledb.php.rar
Filename: functions_pafiledb.php.rar
Filesize: 11.39 KB
Downloaded: 110 Time(s)
Thanks for your help DWho,
yesterday I tested it local and on a testsite.
It is working if you insert the BBCode via frontpage.
If you insert the BBCode via myphpadmin or the BBCode still exist, it only shows the BBCode
  1. Fatal error: Call to a member function parse() on a non-object in /www/htdocs/includes/pafiledb/functions_pafiledb.php on line 1800
Maybe you someone else can figure it out, how to solve it.
oops I forgot you can edit the files by the ACP I will quickly change the necessary files..
sorry I did not read you post correctly about editing in the ACP...
fixed the problem... just upload the attached ACP file...
for anyone else wanting this I have updated my first post with all the correct files
admin_pa_file.php.rar
Description: admin_pa_file.php
Filename: admin_pa_file.php.rar
Filesize: 5.08 KB
Downloaded: 97 Time(s)
Hi
Just checking is everything working as it should now...?
Hi DWho,
sorry for the late answer.
It is working, but not correct.
If you write bbcode, html is stored in db. That is the reason why you see html if you edit one download file.
Do you have a idea to solve this? I changed all to RC1.
yeah it is a right pain...
I have looked at the files and I seen to be missing something somewhere but cannot find it...
I have made it save as bbcode in the database but then it will not show correctly in the files... I have a couple of ideas and will get back to it as soon as I have finished a couple of over things...
will let you know as soon as I can..
Thanks DWho,
no hurry
