Page 3 of 4
Goto page Previous  1, 2, 3, 4  Next
Post Re: My Space Profile Mod
when i get some time i will look at updating this mod with extra features...
my workload is huge at the moment and i am falling behind with work so once i have caught up  i will have a look
Post Re: My Profile Space Mod
I have a problem  after edit settings MPS
Fatal error: Call to undefined function gen_rand_string() in /home/******/public_html/ip/mps.php on line 1482
To The World You May Be One Person ,But To one Person You May Be The World
awillSend private messageSend e-mail to userVisit poster's website
awill wrote: [View Post]
have you any more details... what did you try and do is this a fresh install etc...
sorry it is really hard to diagnose a problem without any information....
i had a look at that script. look´s good to me , could´nt find any error
@DWho > On your MPS demo site, I went on " My Profil Space " > " MPS Settings " and tried to change a random value and when I clicked on submit I got this error :
0py8fownbe
YrosSend private messageVisit poster's website
Yros.............. Its Appears to be the same problem that I face ........My Profil Space " > " MPS Settings
Most of the random value of this mod dose not accept to change....
DWho
i tried to change or delete the random  Group Categories in ACP >>You have successfully deleted the category>>Back To Group Categories>>Nothing Happen >>>its still there.
-IP 1.3
-Fresh Install
-Demo Site
Yros wrote: [View Post]
0py8fownbe
i have just been to the mps demo site and changed all the values .. i received no error..
everything ran as it should...
 what random value did you enter... what exactly did you do.... i need to reproduce the error so I can fix the fault...
DWho
-IP 1.3
-Fresh Install
-Demo Site
ok this error is totally un related to the one you posted before...
there is a small error in the file i have fixed and please find it attached and upload to your adm folder...
admin_mps_group_managment.rar
Description: unzip and upload to your adm folder of your site copy over the original file
main download updated in first post...
Filename: admin_mps_group_managment.rar
Filesize: 3.82 KB
Downloaded: 92 Time(s)
Ok, for the first error ( with screen ) I did that :
> Logged-in on your MPS board
> Went on My Profile Space
> Went on MPS Settings
> Changed " Max Friends To Display: " ( default 8 ) to 5.
> Clicked on " Submit "
> Got that error :
Fatal error: Call to undefined function gen_rand_string() in /home/icyphoen/public_html/mps/mps.php on line 1482
I tryed to change every ( or none ) value and always got that bug. Try to connect under my account for see yourself.
> Got that error :
thanks.. i have changed the code slightly could youi see if the same error appears now on the test site
thanks
thanks ...DWho
-After upload the attachment file  ....Group Categories in ACP work good now >
My Profil Space " > " MPS Settings >>>> Not work
Manage Blog>>>>Error
-weblog_config.php was not found on this server.
awill
try this
open mps.php
find
  1. $key_len = 54 - ( strlen($server_url) );
replace with
  1. $key_len = 54 - ( strlen($profile_server_url) );
I´ve tried it on my test site and i got no prob´s with mps-settings
EDIT:
That´s because that file is missing in the script.
I´ve been reviewing the hole script, can´t see it
spydie.....if you admin its work but loggin as user it's not work
Nothing Chang (Fatal error: Call to undefined function gen_rand_string() in /home/sadadcom/public_html/ip/mps.php on line 1482
 files is missing in the script:
View Weblog >>>>Error
weblog.php was not found on this server
If i try to view profile of my  friend i get this error too
Icy Phoenix Debug] PHP Notice: in file /includes/mps/mps_viewprofile.php on line 1204: include(./includes/weblogs_common.php) [function.include]: failed to open stream: No such file or directory
[Icy Phoenix Debug] PHP Notice: in file /includes/mps/mps_viewprofile.php on line 1204: include(./includes/weblogs_common.php) [function.include]: failed to open stream: No such file or directory
[Icy Phoenix Debug] PHP Notice: in file /includes/mps/mps_viewprofile.php on line 1204: include() [function.include]: Failed opening './includes/weblogs_common.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php')
[Icy Phoenix Debug] PHP Notice: in file /includes/mps/mps_viewprofile.php on line 1205: include(./includes/functions_weblog.php) [function.include]: failed to open stream: No such file or directory
[Icy Phoenix Debug] PHP Notice: in file /includes/mps/mps_viewprofile.php on line 1205: include() [function.include]: Failed opening './includes/functions_weblog.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php')
Fatal error: Call to undefined function get_auth_level() in /home/sadadcom/public_html/ip/includes/mps/mps_viewprofile.php on line 1208
qqqq
ok
icy phoenix does not have a weblog mod anywhere and mps does not come with one...
you need to go back into your ACP mps configuration and turn of the weblog addon that your turned on...
then your errors will dissappear... if you had said you turned weblog on it would have saved a lot of problems
I will remove the function on the next mps update to stop this confusion..
Thank´s for clearing this up.
I thought you might have forgotten to include it
Edit
@awill , are you shure you have all updates for this Mod installed ???
since i´ve checked my mod on my local test site and get no errors so far ( exept the above mentioned by DWHO)
could it be that some of you´re files not clean ??
Thank you DWho, this is a great gift
AerosmithSend private message
Post new topic  Reply to topic  Page 3 of 4
