Post [Mod Release 1.3] Xinha WYSIWYG
This is a wysiwyg editor for the cms only....
Turning this on in your ACP allows you to use html in blocks without the need to know html...
 26_07_2009_11_24_49
Please Download Here
Post Re: [Mod Release 1.3] Xinha WYSIWYG
does the image function work ??
I think i remember some image problems with this
spydie wrote: [View Post]
The image functions works fine... you can upload for your machine save it in files and use it again and again... it does not use icy uploaded images though...
On the tinyMce editor after  3 months of hacking it I found away of uploading images (well found an addon) and saving them in a folder
does this mean i´ve got to create an image folder for this ??
Nope the image folder is already there... try out on a test site...
I have already it set it up to work correctly and tested it on 4 sites now...
Ok i´m updateting my local now.
Problem is i can´t update as fast as you release your mod´s
LOL Let me know how it goes
First tests done.
Run brilliant. If I find an Bug i´ll let you know
First tests done.
brilliant thank you
I have a problem...
When I'm adding this : INSERT INTO `ip_config` (`config_name`, `config_value`) VALUES ('select_wysiwyg', '0'); to my database it gives me this error: #1062 - Duplicate entry 'select_wysiwyg' for key 1
How do i fix this?
LiNDHOLMSend private message
Not an error just states you already have this line in your database... just ignore it as you have all the details you need
DWho wrote: [View Post]
Okay.
But I've put all the edited files in their correct folders etc, but I cant use the wysiwyg and I cant seem to find where I activate it either.
A little help? (A)
check your emails already answered that on my site...
Oh, thank you alot!
