DWho
 [Mod Release 1.3] Topic Cement
This mod will allow the moderator to set a priority for any topic.
The default priority is zero; all topics with a priority of zero
are sorted as they always have been: First by type, and then by
descending topic id. This mod inserts a new sort: First by type,
then by priority (Descending), and then topic id (descending).
It adds a text field in the moderator control panel to assign
or remove priority from any topic.
The intent of this mod is to be used in a forum of announcements or,
in my case, a forum dedicated to distributing official attachments.
The users can reply to my attachment post, but I don't want the order
of the posts to change, so this mod "cements" the order. Or think of
it as moderator-definable stickiness!
Please Download Here
Enjoy
#1 Sun 26 Jul, 2009 13:05 |
Thanks for the useful Topic DWho: KugeLSichA (28 July), Mighty Gorgon (22 November) |
Yros
 Re: [Mod Release 1.3] Topic Cement
Hii **
I just would check something : during the installation, I found it for modcp.php :
- #-----[ FIND ]------------------------------------------
- ORDER BY t.topic_type DESC, p.post_time DESC LIMIT $start, " . $board_config['topics_per_page'];
- #-----[ AFTER, ADD ]------------------------------------------
- ORDER BY t.topic_type DESC, t.topic_priority DESC, p.post_time DESC LIMIT $start, " . $board_config['topics_per_page'];
Isn't it :
- #-----[ REPLACE WITH ]------------------------------------------
Regards,
#2 Sun 30 Aug, 2009 13:29 |
DWho
I do not follow you the code you posted is exactly the same both times...
#3 Sun 30 Aug, 2009 13:47 |
spydie
Mike where are your glasses ??
the point is in AFTER and Replace
____________ Driving me and my PC crazy, trying to create some pluggins
Icy-Mods.com ( IP 2.0 RC-1)
#4 Sun 30 Aug, 2009 18:43 |
Yros
You are here =D
And yes the difference is that it's not " after, add " but " replace with " ^^
Because when I saw where it was placed, it seemed strange to me to have 2 time that kind of line =/ See : default modcp.php part which is interesting us :
- WHERE t.forum_id = $forum_id
- AND p.poster_id = u.user_id
- AND t.topic_poster = u2.user_id
- AND p.post_id = t.topic_last_post_id
- AND p2.post_id = t.topic_first_post_id $where_type
What you tell us to do ( " after, add " ) will does that :
What I think is right ( " replace with " ) :
No ? **
#5 Sun 30 Aug, 2009 20:04 |
DWho
doh..  . yep sorry... was just looking at the code... did not see the replace and after...
thanks for pointing that out i will update the download...
#6 Mon 31 Aug, 2009 11:54 |
Aerosmith
Excuse me, translated with Google
Thanks for the MOD
A proved very helpful
I have a question
This mod is only for administrators?
My moderators can not be used, why?
___________________
Me disculpan, traducido con Google
Gracias por el MOD
A sido de mucha utilidad
Tengo una duda
Este MOD es solo para administradores?
Mis moderadores no lo pueden usar, ¿porque?
Gracias
#7 Sun 22 Nov, 2009 12:50 |
DWho
Hi
I have checked my test site with a moderator and they can use the topic cement feature...
do you moderators have access to that forum..?
#8 Sun 22 Nov, 2009 14:59 |
Aerosmith
hi.
Yes, they have access to these forums.
The moderators do not see this option in the forums that control, left two images
This option, I see on the panel moderators at the end of each topic.
Thanks for responding
_______________
Hola.
Si, ellos tienen acceso a esos foros.
Los moderadores no ven esta opción, en los foros que controlan, dejo dos imágenes.
Esta opción, yo la veo en el panel de moderadores al final de cada tema.
Gracias por responder.
#9 Sun 22 Nov, 2009 15:58 |
DWho
so as admin you can see the changes....?
#10 Sun 22 Nov, 2009 16:07 |
Aerosmith
hi
Edit all files for third time, got on the FTP, delete the forum cache, delete browser cache (use one for Administrator, one for moderator and one for user, for fast access), check permissions.
And finally seen both as Administrators Moderators.
I think my problem was with the browser and the cache.
Thanks DWho,
I'm sorry for the inconvenience.
____________________
hola
Edite todos los archivos por tercera ves, los subí a FTP, borre cache del foro, borre cache de exploradores (uso uno para Administrador, uno para Moderador y uno para usuario, para acceso rápido), revise permisos.
Y finalmente se ve tanto para Moderadores como Administradores.
Yo creo que mi problema era con el explorador y el cache.
Gracias DWho.
Discúlpame por las molestias.
#11 Sun 22 Nov, 2009 16:55 |
DWho
No problem glad you got it sorted
#12 Sun 22 Nov, 2009 18:46 |
nazbox
I have installed this mod but for some reason i cant see the priority on the moderate page.
When I click on "moderate this forum" i can set the priority but after I set it and go back into "moderate this forum" to change the priority I can't see the priority I have already set and so I don't know the number i have used.
The Mod works fine but I just can't see the current priority numbers in "moderate this forum".
Can anyone help?
#13 Fri 18 Mar, 2011 18:57 |
| Link this topic |
| URL |
| BBCode |
| HTML |
