Page 1 of 3
Goto page 1, 2, 3  Next
Post Thanks For All Posts
I want to request if there is any way that i can put a Thanks button for all the posts of a theme and not just for the first.
DanielcSend private messageVisit poster's website
Post Re: Thanks For All Posts
Nope... this feature should be coded... and would require some extra SQL in viewtopic... and I won't code it, because I don't want to charge viewtopic with other unnecessary things.
Thanks !!. Any way.. I'm waiting for someone that port "Karma Mod" for the latest IP ..
why don´t you try yourself Danielc.
It is´nt all that difficult to port an .27 Mod to 1.3
Yeah, i should try it.. I will try when i have some time..
On a more serious note - - -
Daniel,
I do believe that there were two "Thank You" MODS for phpbb2* - One did what the one here at IP does - The other had options for both or one or the other.
IF! you can find the one that does both, I may just look at it to see what needs to be done to it for IP.
Bottom Line: You find it - We'll look at it.
Is this the mod you say?? I am not sure because there isn't a DEMO of the MOD, but i have seen another one mod that is for the first post only..
EDIT: Possibly is this mod.
I'll have a look at both of them later - But a quick read indicates that they are only for the first post.
Will check it out.
Edit:
Ok! Daniel, I have something that may also interest MG and want to run it past him first. Because if he thinks it's worthwhile to add it to Icy Phoenix - Then he can do all the hard work.
I´m with Danielc in this.
because a lot of times you help to fix a problem but can´t receive the thank´s for it, because you posted the fix in the Topic there the question (problem) was.
I understand perfectly what he want´s to archieve
vB I believe has the same thing - Working on it.
Thanks!!! I just wait xD..
Update for you Daniel.
I've got something working in IPv1.2  (Which for me was the easiest way to start) and it does what I think you want it too.
MG has re-coded and "moved" so much stuff in IPv1.3 that I am having some problems working out what is where and coding some sections of it in.
If all else fails - I'm going to ask MG for some help.
I'm going to ask MG for some help. == I'm going to hound him to death!
Excellent News!!! Thanks for your help...
I hope that you can solve your problems!!! And thanks to MG also for the help you may give to Lopalong.
Have a look on this one .
It´s original from 1.0.27, i found it in Todo Mod´s.
should work on 1.3
gracias_mod.rar
Filename: gracias_mod.rar
Filesize: 2.17 KB
Downloaded: 81 Time(s)
Thanks spydie,
But!
That one only covers viewtopic and is hard-coded with db_ prefixes etc. We're working on one that does a lot more and is switchable in the ACP.
The only problem is that I'm waiting for MG to show me how he re-vamped the applicable Admin files because he's moved so much stuff around and changed so much of the script - He totally lost me.
