Page 1 of 3
Goto page 1, 2, 3  Next
Post [MOD IPv1.3.0.*] Sliding Options When Posting
Hello,
*Tip(s) : you can choose to show the content of the menus UNDER the tabs. Everything is explain in the installation.
( @ MG : Maybe another thing to add to the default IP package hm ? ^^ )
  • Name of the Mod : Sliding Options when Posting
  • Description : Replace the long part of options when starting a thread ( posting.php / posting_body.tpl ) by a reducted and animated menu with tabs ( and permissions ), reducting the whole page a lot and making it easier.
  • Version : 1.1.0
  • Démo : n/a
  • Screenshots : ( under Mozilla/Firefox with BlackPearl skin )( It is in English in the package )
    eyo82ltczf
    5ujfnk8cbs
Credits :
@ Informpro for making the code I gave him working with multi-tabs.
@ KasLimon for giving the solution for perms on tabs and idea of lang_var.
~ This mod perfectly work with IP styles ( tested on Pearl and Frozen Phoenix ) but have a little unwanted issue on prosilver_ip : a space between content & tabs.
~ I support every troubles with the code until they are fixed but not the design : You're free to edit yourself the .css and the pictures ^^
Sliding Options.rar
Description: 1.1.0 ~ Fixed a major bug
Filename: Sliding Options.rar
Filesize: 59.73 KB
Downloaded: 158 Time(s)
YrosSend private messageVisit poster's website
Post Re: [Beta] Sliding Options When Posting [For IPv1.3.0.*]
Great looking mod... I will be tesing and adding to my sites
Great looking mod
CostaSend private message
I'm yours ^.^
If anyone have an idea on how to set up the permissions on tabs ... ( as I said, if a user isn't allowed to use this feature, make the tabs hide too ). If you find any bug or if you have any suggest on the code, don't be shy and tell it for let me update the mod with your ideas / corrections ^^.
don't go...
copy all file in ../template/...
but don't go...
paxSend private message
Have you a link of your forum ?
Wich theme are you using ? Did you try another theme ?
Edit : in Local I tested for Black Pearl and Frozen Phoenix : both worked perfectly.
Check in the template folder you are using if there isn't a file " posting_body.tpl ". If yes it would explain many things.
In local.
Theme: ProSilver IP
posting_body.tpl
Thanks Yros.
You could use SWITCH / Block for perm's (because the number of tabs are automatically calculated with the number of li (CSS3: li > a.open)
If anyone have issues with this, tell me
Pax, the main problem with Prosilver IP is that it's an adaptation from Subsilver of phpBB 2.x.x and isn't totally adapted to IP >.> I can't provide support for every theme ( as I can't do buttons for every themes ). This mod is just a little useful code for help in a way.
That's what anyone would have reply but I'm too stupid *sigh*
I just updated the new package with some changes :
- Sliding Option.txt     greatly modified for add all the changes made in posting_body.tpl
- a Contrib folder added with /default/posting_body.tpl already modified and same for /subsilver IP/posting_body.tpl
Pax, just download the new package and upload /subsilver IP/posting_body.tpl in your template directory.
It should be fixed now.
don't go...
1  2
Of course . . . If I forget the main script in the file it won't start >.>"""
Sorry for that. I updated ( again ) the package. Now it's ok ( I tested on local with prosilver_ip black & blue ).
The only thing with prosilver_IP is that I can't explain a little space between content and tabs *hm*
Screen under Mozilla and prosilver_ip Black :
mqcnawg6zn
Ps : I of course updated the whole installation with these modifications. I also added some notices and I cut the code in 4 parts :
<!-- BEGIN / END Sliding Options - Script 1 / Content / Tabs / Script 2 Part -->
I hope it will help you. The script can be used in many other way. Feel free to take advantage of that.
EDIT : I removed [beta] from the title because it now looks like a true mod / plug in for IP. I will try to fix the unwanted space with prosilver's styles and to find a way to add perms on the tabs.
Post Re: [MOD IPv1.3.0.*] Sliding Options When Posting
in the package there are two folder pro silver IP...
Ah yeah ... Package updated ( the right folder is subsilver_ip ). Little mistake with WinRar >.>"
3
You know, if you follow the installation part you haven't to add the file in the contrib directory ... In local it work perfectly for me so if it doesn't for you it's not because of the mod but because of one of your modification. Just download the package again, include again the root/ folder into your root and then add contrib/subsilver_ip/posting_body.tpl into {your_board}/templates/subsilver_ip.
There's no reason it won't work.
