Scrollbar In Signature
Subject: Scrollbar In Signature
Scrollbar in signature [ simple MODification ]
#--------[ BEGIN MODIFICATION ]-------#
FILES TO EDIT (1):
viewtopic.php
OPEN: viewtopic.php
SEARCH:
$user_sig = '<br />' . $board_config['sig_line'] . '<br />' . $user_sig;
REPLACE WITH:
$user_sig = '<br />' . $board_config['sig_line'] . '<br /><div style="overflow: auto; max-height: 150px;">' . $user_sig . '</div>';
NOTE:
Where max-height: 150px; will be the maximum height of the signature, so if you lower the scrollbar is not created then nothing is displayed, while if the above will create the scroll.
DEMO:
-> URL: http://testicyforummods.site11.com/viewtopic.php?p=26#p26
-> IMAGES:
signaturenormal
signaturewithscroll
#-----[ SAVE/CLOSE ALL FILES ]--------------------------------
# EoM :mrgreen:
Subject: Re: Scrollbar In Signature
Nice!
I'm sure it will be helpful. Thanks!
Thank you very much, this excellent. :mrblue: :mrblue:
Greetings
Generation Time: 0.4941s (PHP: 4% SQL: 96%)
SQL queries: 31 - Debug Off - GZIP Enabled
