Post Flashchat And Icy Phoenix 1.3 Bridge
Hi
This is the bridge for the flashchat version 5.0.11 and Icy Phoenix 1.3
To Install please copy over the attached files into the correct folders in your chat folder...
then upload to your server and install as normal.. remember to use phpbbcms for your cms..
follow installation instructions and you are good to go...
This bridge will now show the icy users profile when clicked on in the chat if you come across any errors espcially in the admin section please let me know as I have the fix for them but it only effects certain servers...
A big thank you to MG for rewriting the main cms script to make it better functional for ICY      sh_thanks
Please remember that flash chat is a paid script of $5 I am by no means making any money or endorsing the flash chat site here just making the mod changes so you guys can use it in your Icy Phoenix sites..
Enjoy
flashchat bridge icy1.3.rar
Filename: flashchat bridge icy1.3.rar
Filesize: 8.07 KB
Downloaded: 233 Time(s)
Post Re: Flashchat And Icy Phoenix 1.3 Bridge
Thanks for this!
This chat engine is nice. And the integration works great.  I am going to use this chat as the "public" chat on the main page for our site but for the main members who are chatting (there will be 50 or more chatting at once) this chat just can not handle more than 15 or so chatters at once on a shared host server like my site is.
So I went with 123flash chat,, its a little expensive ($30 a month for 50 concurrent users) but it can handle more of a load.
BUT this chat is very functional and useful if you don't have more than 10 or 15 chatting at one time.
JaculusSend private message
OK....so a real issue...
After doing the install, I try to log in using the entry fields, and it shows loading sounds/skins...but then quits.
I install flash chat normally and loads just fine though.
EDIT: here are the errors i'm getting:
[Icy Phoenix Debug] PHP Notice: in file /includes/sessions.php on line 499: Cannot modify header information - headers already sent by (output started at /chat/flashchat.php:15)
[Icy Phoenix Debug] PHP Notice: in file /includes/sessions.php on line 500: Cannot modify header information - headers already sent by (output started at /chat/flashchat.php:15)
Pyro-TechSend private message
Hi
when setting up flashchat you should set it up to use the phpbb2 bridge then you can replace the files with the ones I have attached and it should work just fine or have you a link so I can see what is going on..
Hello DWho,
Could you please say me the link to download flashchat?
I search in google, but there is a lot of flashchats!!!
Thanks you.
Acuarios, mascotas
Forografia, fotos
Informatica, pc
portalpezSend private messageVisit poster's website
the link is http://www.tufat.com/s_flash_chat_chatroom.htm
though i must add it does cost £5 and I am not promoting this software or site...
FYI
Thanks you!
The version is 6.0.6, the bridge run with this version?
Acuarios, mascotas
Forografia, fotos
Informatica, pc
the bridge at the moment runs on version 5.0.11 I am just downloading version 6.0.6 to see if there are are any problems
Thanks for this bridge!
Its works fine for me.
A question...  Its possible put the flashchat  in a center block on Icy portal?
How can i use it with Icy template?
Thanks again...
EFNSend private message
Hi
add this piece of html code to a center block for it to work the way you want it too..
<IFRAME SRC="http://www.bbful.com/chat/flashchat.php" frameborder="no" WIDTH=100% HEIGHT=500></IFRAME>
you have to edit the files to make it fit with your template sorry I have not gone into file editing with the program to know where to start LOL
Am I safe to assume this works with Milky Way Red?
pyroplantfreakSend private message
should work with all templates.
