Post Parse Error: Syntax Error
hi all I have the following problem, after installing mods Beta-User-Reputation-System and Medal_MOD-IPv1-3 wanting to send a post or view the post me the following error jumps Parse error: syntax error, unexpected $end in /home/blackwor/public_html/viewtopic.php on line 3049
    include(IP_ROOT_PATH . 'includes/page_tail.' . PHP_EXT);
ktemanuelSend private message
Post Re: Parse Error: Syntax Error
I think, you should take a clean file.
and start to edit it again, from the beginning.
first the medalmod, and test it.
Then the Reputation mod and the same testing.
