[SOLVED] AJAX Chat 0.8.3 - Possible? (Update: YES It Is ^_^)
Article
Reply with quote    Download Post
Post Re: [SOLVED] AJAX Chat 0.8.3 - Possible? (Update: YES It Is ^_^)
Mort, the only things I've done are modifications to CustomAJAX... So, it can even be just another package disponible release on the sourceforge of the project ... Or here.
Informpro - View user's profile Send private message
Informpro [ Thu 14 Jul, 2011 02:03 ]
Comments
Thanks,
But I only have one other question.
Why is this topic allowed to run in "General Support" when it should have been moved to here.
Customizations And MODs Discussions
mort - View user's profile Send private message
mort [ Thu 14 Jul, 2011 11:28 ]
Because he first asked for a "howto" ? Does that really matter so much for you ? If we provide the package, the release topic will be in the MODs forum.
Informpro [ Thu 14 Jul, 2011 11:47 ]
mort wrote: [View Post]
As you wish (Moved)
Joshua203 - View user's profile Send private message
Joshua203 [ Thu 14 Jul, 2011 12:23 ]
Informpro wrote: [View Post]
Does that really matter so much for you ?.
Yes it does!
This place does not have a great deal of support, and posting stuff all over the place is not going to help anyone or the Search Engine in future.
But if you want to run it as a "Country Kitchen" - that's fine so long as you can remember where everything is when people start asking the same questions over and over again.
mort [ Fri 15 Jul, 2011 08:38 ]
I think it could really help Icy if one of you would post this integration to their development so it can be included
Joshua203 [ Fri 15 Jul, 2011 08:54 ]
I have nor interest neither intention to start a fight.
I already said it : he first asked for a howto. Which must'nt be placed in "Customizations And MODs Discussions". Therefore, the chat will be provided as a plugin for IP (normally). So, THEN, it will make sense. BTW. Since Joshua moved the topic (thanks to him), isn't this discussion (even before) pointless ? I never said that general support is the best place, but at start it was fitting enough to ask that ...
Discussion closed.
Informpro [ Fri 15 Jul, 2011 21:26 ]
Thanks GS for having suggested this addon, I checked it and it works very well.
Thanks Informpro for having integrated it!
I have ported this chat to the plugin system, so the chat is now working as a plugin.
ACP options should be ported as well... maybe in the future if someone is willing to work on that.
I will add this plugin in the plugins repository next time I will update the package.
Mighty Gorgon - View user's profile Send private message
Mighty Gorgon [ Tue 19 Jul, 2011 22:00 ]
This mod has been ported to latest Icy Phoenix version as a plugin.
https://github.com/MightyGorgon/icy...ster/trunk/chat
Thanks for sharing and helping in integration.
Mighty Gorgon [ Thu 25 Aug, 2011 23:28 ]
Hi MG!
Especially Safari-Problem! Maybe in Chrome, too? (i can't use Chrome, so please try it out. But i guess, yes, same problem.)
I've noticed that the AJAX Chat not really works. => Special example is on Safari (up-to-date or any other Version of it) and the Styleswitcher.
(BTW: did you knew that Safari can't load different (alternate) Stylesheets? So this is the problem.)
You will notice that the styleswitcher works under IE, FF and Opera, too. But if you're using Safari, the Chat will destroy! (Chrome, i don't know, just guess yes)
Do you have a solution for it?
See here using Safari with the StandardStyle "prosilver": http://chat.ecobytes.net/
(even noticed the error message in Safari? You can disable this maybe forgotten string in "js/chat.js" on line 633 (or search for "alert(e);"). Found it? Then just add two slashes before like this: //alert(e);
done - no error message anymore! Maybe it's a general Problem to Safari because it can't play sounds? Maybe it should be quicktime installed? Unfortunely i don't know...)
So, if you now change the style from standard "prosilver" to anything u like, the chat will destroy. See it?
Ok, it can works on Safari, if you set a default/standard Style and delete all other CSS in lib/config.php on line 50+52. But that's not the solution.
Do you have maybe a work around for it, so Safari can load different Styles?
Maybe it's possible to change the Styles using Javascript. But unfortunely i don't know how it's done. It's maybe to add anywhere in lib/class/AJAXChatTemplate.php !?
This could help you further?: http://www.alistapart.com/articles/alternate/
Greetings, Ghostsearcher
Not really important Addendum:
Also it could be, that some Safari users will kicked from the chat after round'bout 20 Minutes. Attention: I don't know if all(!) Safari users got this problem. I just know this from a Safari using friend that he will kicked all 20 minutes from the chat and (like i set this string to "true") re-auto log in again.
So this notice is payed with attention because as i've already said, i don't know if any Safari user will have this problem.
Maybe some Safari users can check this out on the chatlink i posted here in the beginning of this post?
Just login, wait 20-30 minutes and check if you're kicked out. It doesn't matter if you typing or not.
Ghostsearcher - View user's profile Send private message
Ghostsearcher [ Fri 26 Aug, 2011 17:05 ]
Please ask chat-related problems in chat-related forums (or sourceforge, watevar).
Informpro [ Fri 26 Aug, 2011 18:06 ]
Post new topic  Reply to topic  Page 2 of 2
Goto page Previous  1, 2
