Post Replace The Gravitars
Tired of those old, boring and time-worn gravitars - All those different coloured houses and yesterday's graphics
Now you can change them without too much fuss....
And by that I mean once you change the scripts in the zip you can change the images at any time simply by overwriting the files with different ones - But they MUST be GENUINE gif's and NOT re-named .png's etc.
The MOD Instructions:
delete the folder /images/avatars/generator_templates - and replace it with the folder in the zip.
delete the file /templates/default/profile_avatar_generator.tpl - and replace it with the file in the zip.
delete the file /generate_avatar.php - and replace it with the file in the zip.
delete the file /includes/usercp_avatar.php - and replace it with the file in the zip.
Or:
Open:
Find:
        'U_PROFILE2' => append_sid(CMS_PAGE_PROFILE . '?mode=editprofile&cpl_mode=avatar'),
Replace With:
Find:
        'S_PROFILE_ACTION' => append_sid(CMS_PAGE_PROFILE . '?mode=' . $mode . '&cpl_mode=avatar'),
Replace With:
A Nice Picture:
 gravitars
All the avatars are 100x100
The Spidey one if for MG - -
And the .ZIP'S..
The 30 pack is for those who only want a small number of gravitars - But as the Mythbusters say - "If it's worth doing - It's worth overdoing"
So I have added a 65 pack which could also be used to chop and change the 30 pack images with.
Both zip's have the files and instructions..
@MG - I fixed the form errors and closed the open tags in profile_avatar_generator.tpl and validated it - If you want to use it.
gravitars-65.zip
Filename: gravitars-65.zip
Filesize: 364.61 KB
Downloaded: 136 Time(s)
gravitars-30.zip
Filename: gravitars-30.zip
Filesize: 190.64 KB
Downloaded: 143 Time(s)
