Re: [SOLVED] Album Thumbnails Gone After Upgrade?
Because there was some wrong conversion patterns in the function... you were not having the problem with URL Rewrite enabled?
YES, I've told you! I've also clear the whole cache but
ALL worked perfectly... So I don't understand why...
BTW, the important thing is that
NOWit's no more a bug!
~~~ Andrea ~~~
User #379756 on
Linux Counter
