It may be because your apache server is actually configured to compress, even if you disable it in your forum. You will need to ask your host about this. There is evidence of it running in your server config:
The php errors you should be seeing will not be displayed when gzip is active. Without seeing those errors, it will not be possible to say exactly what is causing this to happen. The mod_gzip is usually enabled/disabled in the httpd.conf file, which your host will probably have access to. So ask them.
One question. Noted_DrAgOn, make sure you answer this please. How did you create your SQL database? In other words, when you created a user for the SQL database, what were the Privileges? For this, I mean SELECT, CREATE, INSERT, ALTER, UPDATE, DROP, DELETE, LOCK TABLES, INDEX, REFERENCES, CREATE TEMPORARY TABLES. This is very important to know.
