Post Bug in SubForums.
Hi All.
I have found this Bug related to the Forums and SubForums:
If you take a Forum and you turn it into Link in ACP > Sync. Management and, subsequently, you try to return from Link to Forum the change, it doesn't happen. It needs to make a forced passage turning the Link into Category before and, subsequently, to transform the Category in Forum.
See:
Forum 1 (Change to) > Link 1 ~ OK
Link 1 (Change to) > Forum 1 ~ Not OK. The change doesn't happen. Link 1 remain.
Solution
Link 1 (Change to) > Category 1 ~ OK
Category 1 (Change to) > Forum 1 ~ OK
In Memory of mrTrade
La maturit? della gente si evince da quel dice, non da quello che racconta.
GomeshSend private message
Post Re: Bug in SubForums.
Gomesh, you are the most active bug hunter... I wonder how can you find all these very very very well hidden bugs?
Anyway, I've fixed it in the dev package, together with the Permission List features which is not working fine in XS (only one level of subforums is being shown!).
Thank you!
