Post [OUTDATED] CUSTOMIZATION - How To Insert Sponsor In The Navigation Menu
Open /templates/mg_themes/common/nav_quick_links.tpl
    <th style="cursor: pointer; cursor: hand;" align="left">
        <img src="{IMG_NAV_MENU_SPONSOR}" alt="Sponsors" title="Sponsors" />&nbsp;
        <a href="javascript:void(0);" title="Sponsors" style="vertical-align: top;"><b>Sponsors</b></a>
    </th>
    <td class="row5">
        <div id="sponsors" style="position: relative; padding-top: 0px; padding-bottom: 0px;">
            <table class="forumline-no2" width="100%" cellspacing="0" cellpadding="2" border="0">
                    <td width="8" align="left" valign="middle">{IMG_NAV_MENU_SEP}</td>
                    <td class="genmed" align="left"><a href="http://www.mightygorgon.com/">Mighty Gorgon</a></td>
            </table>
    </td>
<tr class="forumline">
    <th style="cursor:pointer;cursor:hand;" align="left" onclick="ShowHide('sponsor','sponsor2','sponsor');">
        <table cellspacing="0" cellpadding="0" border="0">
                <td><img src="{IMG_NAV_MENU_SPONSOR}" alt="" /></td>
                <td><a href="javascript:void(0)" title="Sponsor"><b>Sponsor</b></a></td>
        </table>
    </th>
    <td>
        <div id="sponsor2" style="display: yes; position: relative;">
            <table border="0" cellpadding="0" cellspacing="4" width="100%" class="forumline-no2">
                <tbody>
                        <td class="genmed" align="center">
                     -----------------> AD HERE <-----------------
                        </td>
                </tbody>
            </table>
    </td>
If you want to replace the img used, you have to edit this part of the code
With this code always show the sponsor, in order to show and hide it like the rest of menu, to make this change code.
         <div id="sponsor" style="display: none; position: relative;">
