(first question sorted out and deleted)
Second question.
He wants a link button somewhere to take people to his website. Creating the buttons is no problem, but where does he put the link code? I am assuming that also goes somewhere in overall_header.html, but where?
Thanks for any help with these issues. Black Pearl is a beautiful theme and we appreciate it!
Linkage: http://blueflamepress.com/forum
2 Questions On Black Pearl - PhpBB 3.0.5
Subject: Re: 2 Questions On Black Pearl - PhpBB 3.0.5
uuhm well if he wants the link to be somewhere around ..home forum new etc etc find menu_block.html
if you look at the other links you can see how it`s done :wink:
If I had some familiarity with PHP, perhaps - but I don't, so that doesn't help me at all. I have no clue what to do there.
Joshua203 wrote: [View Post]
now common it s a small file with a few links how hard can it be to pick one link:
change it into something like:
and add that back in there at a position you want it to be
PS make sure you copy the clean file for back up just in case you want to start over :wink:
<a href="{U_INDEX}">{L_FORUM}</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" />
<a href="MY HOME ADRESS URL.HTML">HomePage</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" />
is it possible that a new window is opened?
look at www.aan-forum.de
I click on chat and it will be opened in the same window.
complete menu_block.html:
<a href="chat/index.php">Chat</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" />
<td class="forum-buttons" colspan="3" width="100%">
<!-- IF not S_IS_BOT -->
<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><a href="{U_REGISTER}">{L_REGISTER}</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" /> <!-- ENDIF -->
<a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" />
<!-- IF S_USER_LOGGED_IN --><a href="{U_PROFILE}">{L_PROFILE}</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" /> <!-- ENDIF -->
<!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" /> <!-- ENDIF -->
<!-- IF S_DISPLAY_PM --><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a><!-- IF PRIVATE_MESSAGE_INFO_UNREAD --><a href="#"> / </a><a href="{U_PRIVATEMSGS}" class="PM-new-link">{PRIVATE_MESSAGE_INFO_UNREAD}</a><!-- ENDIF --> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" /> <!-- ENDIF -->
<!-- ENDIF -->
<!-- IF S_DISPLAY_MEMBERLIST --><a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" /> <!-- ENDIF -->
<!-- ENDIF -->
<!-- IF S_DISPLAY_SEARCH --><a href="{U_SEARCH}">{L_SEARCH}</a> <img src="{T_THEME_PATH}/images/menu_sep.png" alt="" /> <!-- ENDIF -->
<a href="{U_FAQ}">{L_FAQ}</a>
</td>
</table>
<!-- ENDIF -->
<!-- ENDIF -->
<!-- ENDIF -->
</td>
</table>
hi again,
try using target in the href, you may like the target _blank :wink:
great job piet, goodluck and have a nice day :wink:
PS .. looking in the mirror now to find the god part, i don t see it hahahaha
would be nice if you don“t delet questions and answers, since this is a sopport forum, and others might find questions and answers use and helpfull, to sort similar problems in there sites out
brewster wrote: [View Post]
Generation Time: 0.35s (PHP: 6% SQL: 94%)
