Page 6 of 10
Aexo
 Re: [STYLE] - Milky Way
I don't found it.
Is it in forum? knowlege? download database?
____________ Webmaster: EliteMoviles
Server: Sotem.es
Version: Icy Phoenix 1.2.0.27
#76 Sat 12 Apr, 2008 12:53 |
KasLimon
____________ Gabriel Anca
#77 Sun 13 Apr, 2008 10:57 |
Aexo
I don't find the changes in Styles still
Thanks, KasLimosn, But I only found the file to install, not changes in styles.
what can I change Milky way without loose any mods and modification which I made?
Server: Sotem.es
#78 Sun 13 Apr, 2008 12:43 |
JANU1535
The Code Changes Aexo.
You have to look at the files that were modified in the folder /styles/.
Greets.
____________ www.JanuWeb.Com - Webmaster
www.phpBB-Es.Com - Administrador
#79 Sun 13 Apr, 2008 13:22 |
Aexo
ah! ok.
I was looking for a text file with changes, so I could change it by code. Then have I to edit the new files and upload it? 2 files are very modified
well, I'll do it.
Thanks about your pacient.
Server: Sotem.es
#80 Mon 14 Apr, 2008 17:48 |
xmenfile
Very nice thank you MG
FYI: I have installed it and noticed this on my site and IP test site.
#81 Mon 09 Jun, 2008 09:42 |
Which browser are you using?
Can you add a link please?
#82 Mon 09 Jun, 2008 13:23 |
xmenfile
absolutely MG, I am using IE7 and here are the links:
my test site
IP PHPBB3 demo:
#83 Mon 09 Jun, 2008 15:38 |
osama_gma
hehe it is just a column to display Post Icons
to make sure edit one of the topics and choose Topic Icon and submit it will display that icon in the empty space
If you don want to display it in a dedicated forum .. you may disable topic icons from admin panel
Regards,
#84 Mon 09 Jun, 2008 21:46 |
xmenfile
Thank you Osama_gma. i am trying to know phpBB3
#85 Tue 10 Jun, 2008 22:16 |
I confirm that the space is reserved to topic icons, but what is strange is that in IE there are no borders of the cells...
I will check...
#86 Thu 12 Jun, 2008 11:21 |
alphatran
There is a problem, Mighty
By testing the template in some screen size, I think Milky way have a fixed width, right ?
Now I want to have more space at left side and right side of screen (on all screen size), how can I do this ?
This will anable us to add some Google adds !
#87 Tue 12 Aug, 2008 04:33 |
750 is too few to contain the language vars of your forum.
Try to increase the size or to reduce the font of the menu bar.
#90 Thu 21 Aug, 2008 13:12 |
Page 6 of 10
| Link this topic |
| URL |
| BBCode |
| HTML |
Similar Topics
Similar Topics
