Page 13 of 13
Goto page Previous  1, 2, 3 ... 11, 12, 13
Go to page
Post Re: [STYLE] - Black Pearl And Rainbow Pearl
I have designed the style based on subSilver, but the real issue is that subSilver tables are differents. And there is no way to have those kind of rounded corners with subSilver current template (unless you are going to rewrite it using HTML 5 and CSS 3 features).
That means that you can use "inheritance", but then you are not going to get properly rounded tables. This is the reason why I didn't enable inheritance.
You can try doing that and displaying the result, if you are satisfied with that, you can leave the option enabled.
I noticed the German Black Pearl buttonpack for phpbb3 is missing these buttons (thanks to Faethor, who made me notice ):
3buttons.rar
Filename: 3buttons.rar
Filesize: 3.26 KB
Downloaded: 22 Time(s)
For Rainbow Pearl too
On my local hdd i have all buttons insite
Maybe MG changed something... thanks for reporting it
Honestly I don't know what happened!
Steffen, when you have some time can you please send me again those buttons for all languages?
Styles updated for phpBB 3.0.11.
I send you blackpearl buttons for 18 languages
Rainbow Pearl need some extra time.
Thanks Steffen, I have updated the download page for Black Pearl.
As I decided to use Black Pearl theme as our forum main theme, I have translated all Buttons to Estonian.
Unfortunately I wasnt able to get original font, so they are slightly different, but still close enough.
Also I would like to share those to others, but I dont know how...
Etz - View user's profileSend private message
Etz wrote: [View Post]
i think the best way to do this is that you put all buttons in zip file and upload here in new topic
you can use add attachment below
Limun - View user's profileSend private messageView user's personal gallery
Limun wrote: [View Post]
Right... and maybe one of us can make some time free to make them have the correct font
Thanks for your effort sofar Etz!
Will upload them later, when I get home.
Anyway thanks for your support...
please try to add a text file with all button tranlsations clearly typed (like "quote_button.png = Quote"), so we can copy text easilly when we add the correct font.
Ok, as you will recreate those with original font, you have less work than I had.
As some of those arent translatable to estonian and we use same terminology.
For example IP is IP, Jabber is Jabber, etc.
I had to redo all, as I didnt have correct Font, so I used Trebuchet MS to match the theme...
Texts.zip
Description: Plain text Estonian Translation. Non translatable terms excluded.
Filename: Texts.zip
Filesize: 565 Bytes
Downloaded: 10 Time(s)
black_pearl-extras-et.zip
Description: Couple extra "Black pearl style" buttons for Mods. Translated to Estonian language.
Filename: black_pearl-extras-et.zip
Filesize: 3.27 KB
Downloaded: 8 Time(s)
black_pearl-et.zip
Description: Black pearl imageset, recreated in Estonian language.
Filename: black_pearl-et.zip
Filesize: 29.29 KB
Thanks for sharing these buttons.
As soon as Steffen has some free time I'm sure he will re-do the buttons with the right font (Bank Gothic if I remember correctly!) and I will update the download link for the style.
Thanks!
Yes, I will do the buttons...
Thanks for sharing it.
Post new topic  Reply to topic  Page 13 of 13
