Post SOLVED - [Black Pearl] No New Topic Button
I've recently install a fresh phpBB3 forum with Black Pearl template but I've a furious problem, post message button not appear ! (whith no change in files)
if I use prosilver template, button is good. (we can suppose that is not a right problem)
If I check HTML code from IE, i see posting.php call :
<div id="pagecontent">
    <table width="100%" cellspacing="1">
        <td align="left" valign="middle"><a href="./posting.php?mode=post&amp;f=19"></a></td>
        <td class="nav" valign="middle" nowrap="nowrap">&nbsp;Page <strong>1</strong> sur <strong>1</strong><br /></td>
        <td class="gensmall" nowrap="nowrap">&nbsp;[ 0 sujets ]&nbsp;</td>
        <td class="gensmall" width="100%" align="right" nowrap="nowrap"></td>
    </table>
Someone may help me to resolve this problem or give me a way to search ?
Congratulations for the work done !
Take Care,
- Spoke, french user -
Spoke - View user's profileSend private message
Post Re: [Black Pearl] No New Topic Button
Hi Spoke,
I know phpBB3 is not really supported here since IP runs on phpBB2.  You might check in your template's image folder and make sure the new topic button image is there.
Chaotic - View user's profileSend private messageVisit poster's websiteView user's personal gallery
It seems that problem is linked with french traduction    i use french phpBB3
And finally i do this :
- create a "fr" directory in "php_root/styles/black_pearl/imageset/"
- create "imageset.cfg" file into "fr" directory
- copy button_topic_new.png and button_topic_reply.png files into "fr" directory
- insert 2 lines in "imageset.cfg" file
And buttons are visibles !!!!
Post Re: SOLVED - [Black Pearl] No New Topic Button
So the "new topic" button shows up now?
Spoke wrote: [View Post]
Yes, that is why!
If you can translate these strings we may create even French translations when we have time:
http://www.icyphoenix.com/viewtopic.php?f=5&t=789
http://www.icyphoenix.com/viewtopic.php?f=5&t=789&p=7823#p7823
P.S.: Chaotic, remember that I have released Black Pearl even for phpBB 3.
Sorry for my no answer but I tagged my post "SOLVED" and I did not think that I would have other answers
I try this week to write french translation for Icy Phoenix buttons.
PS : Sorry for my strongly English
Edit : french translation is OK
If you send me the buttons I may add them into download section.
I just translate words in this thread http://www.icyphoenix.com/viewtopic.php?f=5&t=789&p=7823#p7823
I have no graphics skills
