Comments |
Re: YouTube BBCode
thanks MG, i was so happy that i tried this immediately but what i was afraid of is exactly what it does...
{postrow.POST_ID} is not accepted in bbcode replacements, it is just not replaced so it still looks like {postrow.POST_ID} after making a post and viewing the source of the page
as far as i know it will accept anything from the language directory but that would be just about all it would accept? i hope not
thanks for the heads up sofar though
Joshua203 [ Fri 05 Feb, 2010 13:06 ]
Re: YouTube BBCode
And what about using PHP switch in template?
http://area51.phpbb.com/phpBB/viewtopic.php?f=26&t=29448
<!-- PHP -->mt_rand(100000, 999999);<!-- ENDPHP -->
This will generate a random number you can attach to your ID.
Mighty Gorgon [ Fri 05 Feb, 2010 14:58 ]
Re: YouTube BBCode
wow if that would work i ld be in seventh heaven
i m not sure how but i will try, see what it it will bring and report back (hopefully with a positive answer )
would be great if this works .. it would only leave me with one similar (but more complicated to me) bug hunt
Joshua203 [ Fri 05 Feb, 2010 15:28 ]
Re: YouTube BBCode
He he he... we will sort it out...
Mighty Gorgon [ Fri 05 Feb, 2010 16:12 ]
Re: YouTube BBCode
just for your info... i haven t forgotten about this and i will get back on this one (i just got distracted)
Joshua203 [ Thu 11 Feb, 2010 17:31 ]
Re: YouTube BBCode
He he he... then close YouTube and go back coding!
Mighty Gorgon [ Sun 14 Feb, 2010 12:20 ]
Re: YouTube BBCode
Joshua203 [ Sun 14 Feb, 2010 14:09 ]
Re: YouTube BBCode
Also if you add (" allowfullscreen="true" )
This will allow the Board member to view the Video Full Screen on the Forum.
instead of going to "YouTube" for that Option.
Like So.
<object width="425" height="350"><param name="movie" value="h**p://***.youtube.com/v/{TEXT}"></param><param name="wmode" value="transparent"></param><embed src="h**p://***.youtube.com/v/{TEXT}" type="application/x-shockwave-flash" " allowfullscreen="true" wmode="transparent" width="425" height="350"></embed></object>
St0ney [ Fri 23 Nov, 2012 17:26 ]
Re: YouTube BBCode
This is What I actually Use for the YouTube BBC Code. (My Post above was a addon to what was posted.)
This BBC code
a) Will center the Video in the Post
b) Allows Full Screen View
c) Make video Larger - width="640" height="385
BBCode usage:
[youtube]http://www.youtube.com/watch?v={IDENTIFIER}[/youtube]
HTML replacement: (Changed Thanks MG)
<div style="margin: 0 auto; text-align: center;"><br><object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/{IDENTIFIER}&rel=en&fs=1&color1=0x234900&color2=0xd4d4d4"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/{IDENTIFIER}&rel=en&fs=1&color1=0x234900&color2=0xd4d4d4" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object></div><br />
Help line:
[youtube]http://www.youtube.com/watch?v=_Zh5mXvkaMk[/youtube]
St0ney
St0ney [ Sat 24 Nov, 2012 21:50 ]
Re: YouTube BBCode
Many thanks for sharing this tip.
Anyway I would suggest not to use the tag CENTER as it has been discouraged.
When I need to center some content I always use a DIV:
<div style="margin: 0 auto; text-align: center;">YOURCONTENT</div>
Also make sure you close properly BR whether you add it => <br />
Mighty Gorgon [ Sun 25 Nov, 2012 11:20 ]
Re: YouTube BBCode
Thanks MG - Changed the Code above and on my Board.
I'll need to look at the code on my board, I'm sure I have a ton of <CENTER> Tags.
I'm a old HTML guy, so I'm not up to date on proper php coding.
St0ney [ Sun 25 Nov, 2012 17:19 ]
Re: YouTube BBCode
Thanks St0ney,
I will certainly give this one a try
Joshua203 [ Mon 26 Nov, 2012 22:24 ]
Re: YouTube BBCode
Don't worry... HTML is changing day by day... it's impossible to be always up to date.
You can refer to this link to check your code against rules: http://validator.w3.org/
You don't have to be 100% compliant, but the most you can fix, the better it is... and you can reasonably expect that most browsers will display your site properly.
Mighty Gorgon [ Mon 26 Nov, 2012 22:59 ]
