[TIP] Easy ReCaptcha Restyling
Article
Quote    Download Post
Post [TIP] Easy ReCaptcha Restyling
Hi all,
When you want to use ReCaptcha on your forum you may feel that it does not quite fit your style, there is an easy way and a hard way to adjust this... below I will describe the easy way:
For this example I will choose black pearl because this is the style my own forum theme is based upon...
Open styles/black_pearl/template/captcha_recaptcha.html and find:
    var RecaptchaOptions = {
        lang : '{LA_RECAPTCHA_LANG}',
        tabindex : <!-- IF $CAPTCHA_TAB_INDEX -->{$CAPTCHA_TAB_INDEX}<!-- ELSE -->10<!-- ENDIF -->
replace it with:
        theme : 'blackglass',
Open the styles/black_pearl/template/theme/stylesheet.css and at the bottom paste the following on a new blank line:
/* === reCaptcha corrections === */
#recaptcha_table {
   background-color: #121212;
#recaptcha_response_field {
    color: #FDC400;
    background-color: #111111;
    font-family: Verdana, "Trebuchet MS", "Lucida Grande", Helvetica, Arial, sans-serif;
    font-size: 1.3em;
    line-height: 1.4em;
    font-weight: normal;
#recaptcha_response_field:hover {
    color: red;
    background-color: #232323;
To also make it look the same in your ACP-example open... adm/style/captcha_recaptcha.html in there replace the same as described in the first two code boxes above!!
And make the same stylesheet changes in... adm/style/admin.css
That's all  ...you can now purge the cache to complete this job  :wink:
Styles you are allowed to use are:
blackglass, red, white and clean
Enjoy,
...Joshua203
Edited by Joshua203, Tue 30 Oct, 2012 15:19: typo correction
Joshua203 - Profile PM
Joshua203 [ Wed 30 Mar, 2011 18:29 ]
Comments
Design by DiDiDaDo
Generation Time: 0.1582s (PHP: 38% SQL: 62%)
SQL queries: 17 - Debug On - GZIP Enabled
