Post Set Menu Bar In Portal Page
Hi there
Here I go again with a Question
How can I set the Menu bar (its shown in the forum) in my Portal page?
Thanks Joshua for this tip
faethorSend private message
Post Re: Set Menu Bar In Portal Page
Which portal are you using? edit...sorry Board3 Portal!
is there a portal.html file in your template files? if yes please attach it
I have only a portal.php
Is that the one?
portal.zip
Filename: portal.zip
Filesize: 2.01 KB
Downloaded: 154 Time(s)
styles/BP/template/portal/portal_body.html ?
and while you're at it.. your overall_header.html please
Here you go
Folder_p_m_b.zip
Filename: Folder_p_m_b.zip
Filesize: 4.2 KB
Downloaded: 164 Time(s)
Don't ask me why this is added but I think you need to remove some stuff
Please replace this:
  1.     <!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->
  2. <!-- INCLUDE menu_block.html -->
  3.     <!-- ENDIF -->
with this:
  3.
and let me know
EDIT: .... ooooohhwww ...in overal_header.html
Joshua, YOU are my hero!!!! Thank you very much for supprting me!!!!!!! How can I thank you?
faethor wrote: [View Post]
By marking all your solved threads as "SOLVED" (you can do that right bottom of the page.. "Title edit")
and additionally by replacing:
#wrapcentre {
    margin: 15px 15px 0 15px;
with this:
#wrapcentre {
    margin: 0px 15px 0 15px;
in your stylesheet... I may not be a tattoo-artist but this hurts my eyes
Great, I will do that, now I found this button
What is the different if I do this change in the stylesheet?
Try it and look at the top of your page
There's much more to correct but if I tell them all that would mean you get bored because there's nothing to do anymore    l_rofl
Sorry I was wrong it must be another reason you have this extra height above the top of you forum
Please change it back
Ok, I will change it back
Instead...
Change in overall_header.html
<td height="150" align="left" valign="middle"><a href="{U_INDEX}">{SITE_LOGO_IMG}</a></td>
to:
<td height="128" align="left" valign="middle"><a href="{U_INDEX}">{SITE_LOGO_IMG}</a></td>
Though I'm a bit confused to where you hid your top site logo
HideSimilar Topics
