Page 2 of 2
Goto page Previous  1, 2
Post Re: Black Pearl PM Problem
maybe Limun can post it but I think it s unmodified so we could extract it from a default pack too I guess
Both mine and Default posting_body are identical and contains this as text area and palette:
        <!-- INCLUDE posting_buttons.html -->
            <td valign="top" style="width: 100%;"><textarea name="message" rows="15" cols="76" tabindex="3" onselect="storeCaret(this);" onclick="storeCaret(this);" onkeyup="storeCaret(this);" onfocus="initInsertions();" style="width: 700px; height: 270px; min-width: 98%; max-width: 98%;">{MESSAGE}</textarea></td>
            <!-- IF S_BBCODE_ALLOWED -->
            <td width="80" align="center" valign="top">
                // <![CDATA[
                    colorPalette('v', 7, 6)
                </script>
            </td>
            <!-- ENDIF -->
        </table>
EDIT:
One difference with my modded file is:
rows="17"
instead of 15
EDIT: but this doesn't cause the error ..I tested
Edited by Joshua203, Fri 25 Jan, 2013 14:15: STRIKED the false conclusion
ok guys look
i downloated black_pearl from this site
what i changed was this two things:
#wrapper{
    /* clear: both; */
    margin: 0 auto;
    width: 960px;
    /* width: 90%; */
to
#wrapper{
    /* clear: both; */
    margin: 0 auto;
    width: 90% !important;
    /* width: 90%; */
and
<!-- DEFINE $MG_GLOBAL_WIDTH = '960px' -->
to
<!-- DEFINE $MG_GLOBAL_WIDTH = 90%' -->
i also checked on Joshua site and saw this:
 joshua
so it happend also on Joshua site
I'm viewing this at more than one site with multiple widths from default to 100% and use ie8, but  I just don't see it.
I'm almost at the point of blaming your settings on the pc... have you tried viewing on a different system?
nop..
i will try from Linux later
ok summary :
i tryed in Linux and everything is ok , no problems but:
my Linux was on 1280x1024 resolution
my windows 7 (here was the problem) was on 1152x864
now i changed win7 to 1280x1024
what resolution is your Josh?
try 1152x864
wouldn't that simply mean you are using the wrong resolution settings?
My laptop is set at 1280x800, I have no 1152x864
no its not wrong
i think some people still using 1152x864
Hey fella's,
If resolution is the problem, then the script is fixed-width and not fluid.
@Limun, could you set the columns to something like 20 for a look, and then remove all columns and rows, and try it with the style= on its own?
And I suppose another problem is - Is that some browsers are smarter than others, and handle overall and inner widths differently.
mort wrote: [View Post]
i m a bit confused here
what where ?
Wherever that textarea is or called from.
Mate if you use FF and add this to it http://chrispederick.com/work/web-developer/ you will be able to edit the cached html and find and solve these problems a lot easier.
ok
thanks for the link..its very usefull
If you install it make sure that you enable the bottom tool-bar, because that's the one that will tell you if there are errors or warnings in the html - and you can click the icon to find out what they are.
Doesn't tell you how to fix it - But shows you where it is.
And don't ever use Html-Tidy to try and fix it, because you're dealing with lots of different templates when you are looking at the html.
But you already knew that.
Post new topic  Reply to topic  Page 2 of 2
