Post NEED HELP?
I used the following code on my own forum to move the PM and email buttons from under a post to inside the posters profile:
    template: viewtopic_body.html
    search for...
    Code:
                       <!-- BEGIN custom_fields -->
                          <br /><b>{postrow.custom_fields.PROFILE_FIELD_NAME}:</b> {postrow.custom_fields.PROFILE_FIELD_VALUE}
                       <!-- END custom_fields -->
                    </span>
    and add after...
    Code:
                    <br />
                    <!-- IF postrow.U_PM --><a href="{postrow.U_PM}">{PM_IMG}</a> <!-- ENDIF --> <!-- IF postrow.U_EMAIL --><a href="{postrow.U_EMAIL}">{EMAIL_IMG}</a> <!-- ENDIF -->
UPDATE...
Well I just tried adding this code and it does not do anything with this style for some reason. I figured the template for viewtopic_body.html would be the same for all styles, but it obviously is not. Yes - I refreshed the style after the edit. No effect. Bummer:(
Can anyone please suggest an alternative code - my son really wants this like my forum.
mikemikeeeSend private message
Post Re: NEED HELP?
Do you also want to move the Profile button?
Do you want to move it on the left column, under the avatar/post count?
